Question about GE Combination 106687 Upright Vacuum
When putting the hand held section back together, i did not have the filter section connected properly. Now I cannot take it apart to empty it bagless area. Please help me. This is my favorite handy vacuum.
Loss of suction
do not connect to electricity at this point claim a little work area put a blanket down as you are going to strip it all down into little bits clean and then put it all back,
Take apart power cable unwrap, unclip middle glass cylinder section to empty rubbish out, there should be a filter at the base that you can see now unclip clean put back, empty rubbish out of cylinder clean base and top rubber section and filter section with fine brush, use a wet cloth to wipe clean all black rubber suction connectors put back, at the back there will be a hose connector at the base unplug clean put back and make sure no debris is in any of the connectors and underneath where the floor brush is before you start puting it all back , Hope this helps
Feb 17, 2014 | Eureka AirSpeed Bagless Zuum
How do you open the hand held vacuum to empty the contents??
There is Dust cup release need where the power cord connect to the vacuum. Once you have released the dust cup from the vacuum. First the are 4 parts to the dust cup, The actual dust cup, the housing for the filter and mesh screen. The dust cup will unscrew from the the housing which holds the filter and mesh screen. You can also pull out the filter and mesh screen out of the housing, If you have taken it apart fully you will have 4 seperate parts.
Jan 24, 2011 | Fantom Vacums FM430 Handheld Vacuum
Hi, i took apart filters to clean in my dyson dc25 and put it back together as said...and now its making a highpitch whinning sound
Hi its Darran at Dyson.
It may be worth taking the filter in the ball out and putting it back making sure it has clicked back into place securely.
If you need advice on this, please visit our website at www.dyson.com and click on the support section.
Alternatively, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Apr 15, 2010 | Dyson DC25 All Floors Bagless Upright...
How do i open my dirt devil kone to empty it?
remove vac from charging base. twist the two section apart. it will turn about 1 inch and then pull apart. this will expose the filter to remove to empty the dirt. reassemble in reverse.
Jan 21, 2009 | Dirt Devil KONE Hand Vacuum MO213BLU...
Grab the upper and lower conic sections, one in each hand. Twist the lower section clockwise to remove from the upper section. The filter is in the section - remove and empty, then replace and twist back to close and lock.
Power to power carpet head
it sounds like the spring on the cord reel let go. difficult to reinstall. it may have been broken already and that is why it came off. it is rather meticulous trying to work on a cord reel. many can't be disassembled without breaking
Aug 09, 2008 | Miele S548 Bagged Canister Vacuum
It just quit
I took it apart and cleaned it a little and put it back together and it works.
Jul 21, 2008 | Euro-Pro Shark EP366 Handheld Vacuum
Dyson dc07
You can take the clear part off pretty easily, but the upper cylcone section is held on by three star screws on the upper -handle end. After taking those off, the handle comes off and it has a long stick that runs down the center of the cylinder. There are now 8 cyclones facing you. Clean them however you want, but I couldn't get it broken down any further. There are three more star head screws down the center, but after taking them out, I couldn't get the purple upper piece apart from the lower, grey piece. So, I just kept it all dry, pounded on it with a rubber hammer to break the crust off everything, ran a screw driver into each of the cylclones to clear them, and put it back together. Make sure you put your hand down at the bottom when you're trying to line up that stick to put the handle portion back on the whole assembly. If it doesn't make it back in it's little home, it won't empty correctly.
I hope this helps.
Joe
Apr 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
GE Combination 106687 Upright Vacuum Logo
22 people viewed this question
Top GE Vacuums Experts
Gerry Harvey
Gerry Harvey
T bone 1963
Are you a GE Vacuum Expert? Answer questions, earn points and help others
