Question about Kenmore Refrigerators
My refrigerator works but the freezer will not freeze liquids. The ice maker works sometimes. What could be the problem.
  • 1,998 Answers
Two thing could be your issue one would be to check the compressor fan and assure that it is constantly spining when these fans get old they tend to turn spiraticly and if this were to happen then the fan would not cool the compressor properly causeing a slight warm up in your unit until the compressor fan was able to start working again as to the icemaker the icemaker does not make ice unless the unit is at 32 degrees. Also if the compressor fan is runnning fine remove the rear wall of the freezer behind this panel is your evaporator coil if you remove the panel and find an ice build up on the evaporator this would be termed as a defrost issue and you would need to test by doing continuity tests on the defrost timer ,the defrost heater and the defrost thermostat as well if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has fully concluded it allows me to continue helping others in similar situations in the future Thanks Rick
Posted on May 29, 2011
Was useing the water....then the door alarm came on and now the water and ice maker is not working
try this ,in the back of freezer there is a tube that feeds ice maker sometimes it freezes up aim a hair dryer at the tube for 5 to 10 mins ,not to close or it will melt
Apr 13, 2013 | Maytag MFI2266AES Stainless Steel Bottom...
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Deawoo fridge freezer FDF-358 freezer is cold, fridge is not getting cold
The freezer section is working,but fridge is not because defrost door is blocked.Its a defrost cycle issue.
These will help.
Thanks,.
Refrigerator model rb215labp The fridge freezes, fridge drawers freeze, top shelf is too warm
Its not working.Two possibilities,either faulty compressor or issue with defrost assembly.Defrost cycle not working.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Door alarm doesn't work
The sensor is got faulty,which triggers the alarm or its wiring is got loose.Also see if the freezer or fridge component got over freezed with ice modules.
These will help.
Thanks,.
Dec 22, 2012 | Whirlpool WRF560SFYM 19.6 cu. ft. French...
Water in freezer
Most refrigerators today are ice maker ready. If the plugs that were installed in the cabinet and freezer compartment that are used to plug the "ice-maker ready" holes are removed, then moisture seeks it's way into the freezer and freezes.
You will need to replace the plugs to prevent this from happening. Do not use tape to cover the holes as most tapes are not watertite. You should be bale to find replacement plugs at your nearest home center, or from the manufacturer of the refrigerator.
Jan 15, 2009 | Whirlpool Refrigerators
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
140 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
