Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My RCA D52W23 HDTV has a blue, green, and red line across the the top of the screen. The picture looks curved and like the three colors don't line up. Is this a convergence problem? Can I fix it my self?
  • RCA Master
  • 8,617 Answers
Yes you can get the convergence repair kit for your model from www.tvrepairworld.com the kit contains the parts and the repair instructions on cd
Posted on May 29, 2011
Projection tv has 3 versions of what is on tv instead of one
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 26, 2010 | RCA D52W23 52" HDTV CRT TV
The picture looks 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Picture problems
check for cold solder joints around the flyback transformer and a open pico type fuse very close to it. they are rectangle in shape and ususually the one in the middle of the three is the culprit. The problem is in the pincushion circuit
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
175 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
