Question about GE Profile WPRE8100G
Exploded view GE WPRE8100GOWT the bucket violently shakes, seems to be a connector rod missing from under the motor mounting area, this looks to stop the bucket from moving back and forth. I need to know this part number if it exists. Thank You!
  • 1,998 Answers
Hello this is the schematic for your entire machine click here http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Washer-Parts/Model-WPRE8100G0WT/0432/0153200?searchedModel=WPRE8100G&blt= and this is the blown up version of the drive and motor area of the unit as well click here http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fG6090002-00004.png 414 and 415 are the main stabilizers for this unit is this what your talking about or if it is another piece message me back which number it is in any of these diagrams I await your reply Thanks Rick
p.s this is the part number for 414 WH16X10057
and this is for part number 415 WH16X545
Posted on May 29, 2011
Bought Matag MAH8700A used and seller said the washer had a broken leg mount. When running my first load, it started vibrating and walking terribly with 20 min left on the cycle. I had to pause it due to...
ok, if it is shaking that bad it has more damage than you might think,, first open the door and look at the gasket, it should be nice and round, not flexed or under strain,, then try to take it of of the pedestal and run it,, if this helps get a new one,, the shocks wouldnt cause it to shake real bad,, it could be a bad spring, or a counter weight issue, but it sounds like it might have been dropped for a leg mount to be broke,, i have never seen one break without a GOOD REASON
Jan 19, 2011 | Washing Machines
The bucket is banging back and forth violently causing the machine to move around. We made sure the load was evenly distributed but it continues to bounce around at the 15 minute left mark on the cycle...
Check the suspension rods inside the machine. Sound like one has come off or has broke. Here is a link to the part if you need it. The white ones are for the rear of the tub, and the green ones are for the front.
Jan 04, 2011 | GE Profile WPRE8100G
My jeep starts shaking violently when it reaches 55 miles/hr.
no its your wheels well out of balance get them looked at first fitting a damper wont stop this shimmy
Jun 04, 2010 | 2000 Jeep Grand Cherokee
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
Mar 12, 2010 | Maytag NFW7200TW Front Load Washer
The tub is offline and shake the washer violently
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 12, 2009 | Kenmore Washing Machines
Kenmore he2 washer shakes violently
Sep 07, 2009 | Kenmore HE2 Plus Front Load Washer
My front load washing machine shakes violently in the final spin cycle. It is brand new and sits level.
Also - be sure the drum locking (transit) pins were removed by the installer.
Jul 03, 2009 | Kenmore Washing Machines
Spin cycle speeds up to the point of violent shaking
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Mar 24, 2009 | Kenmore Washing Machines
My amana front load washer starts to shake violently then shuts down..........its only half full
Jan 19, 2009 | Washing Machines
Washer shakes violently
The drum mounts to a spindle on the back. On these units, it is common for the tripod mounts for this particular design to crack and break. On every call I have had for a terrible vibration on these models, this has been the problem. The remedy is to replace the front and rear tub, as well as the basket. It is also recommended that you replace the drain pump at the same time. Most of this should be covered under at least a parts warranty.
Oct 25, 2008 | Frigidaire Affinity ATF7000ES Front Load...
GE Profile WPRE8100G Logo
216 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
