Question about Mustek V600RZ Theater System
No sound from rear speakers. Mustek DVD V600RZ tks giuliano
  • 1,940 Answers
This is almost always due to a bad speaker connection in the speaker output terminals on the back of the receiver unit, or the speaker input terminals on the back of the speakers. Check your wire connections at these points and fix as necessary. If the plastic wire insulation is pushed inside the terminals, it will prevent the wire from making contact in the terminal.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on May 29, 2011
No sound after a storm how can I troubleshoot the problem?
Hello, first try suing a dvd to see if you have sound. then make sure all of the audio settings are correct for using internal speakers, if they are, try hooking up an amp it the audio outputs and see if you get sound. If you get sound it may have damaged the audio output ic or related components and using an external amp is the most economical route to go....tks
Jan 26, 2015 | Mitsubishi WD57731
My scanner is a bear pow 1200cs it just to work with window 98 now i have window vista and do not work now ,what i can do.tks.
Download the driver. Well, it looks like this one does'nt have a vista driver. Download the windows XP driver and try your luck. Use the link below for download and instructions.
http://www.mustek.com/mustek/supportdrivers.php
Jan 23, 2010 | Mustek Be@rPaw 1200CS Flatbed Scanner
When on 5.1 dvd ther is no sound from rear speakers,but i can run the test tone ok
check to see that the dvd player sound setting is set to BITSTREAM and not pcm. pcm is only 2 channel. Then check to see that the volume setting for the rear speakers in dvd is up, most sony receivers hold different settings for different applications, (vid 1, sat/tv, dvd) and remember when you switch between them. Rear surround should be up all the way , I believe for your receiver that is +10 also make sure you enable the rear speakers in the setup menu for surround sound.
Nov 28, 2009 | Sony STR-DE525
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
I cannot play avi films
No information available on Mustek website on this model number
You can contact support at this link
Jul 17, 2008 | Mustek MP72 Portable DVD Player
NOT RECIEVING SOUND FROM ALL SPEAKERS WHEN PLAYING CD/DVDS
CANNONT RECIEVE SOUND FROM THE FRONT N REAR SPEAKERS WHEN PLAYING A CD/DVD. THE RADIO AUTOMATICALLY PLAYS THROUGHTOUT THE CAR. WHEN SRC DVD/CD IS SELECTED NO SOUND EMERGES. SO I PUT ON THE DUAL ZONE. AND THE ONLY WAY TO HAVE SOUND IS TO HAVE ONE ZONE TUNER, AND THE OTHER DVD. WHEN I REVERSE THEM OF COURSE THE SOUND WILL SHIFT EITHER FRONT OR BACK. IF U CAN HELP ME FIX THIS AND RECIEVE SOUND FROM ALL SPEAKERS WHILE CD/DVD anPLAYING I WILL APPRECIATE IT. THIS IS COUPLE MONTHS NEW. IT WORKED ONCE OR TWICE IDK HOW THOUGH. AND NOW I'VE TRIED IT ALL BUT STILL CANT FIGURE IT OUT. i went into the zone control and turn off the rear and i still have nothing. pleease help
Oct 08, 2007 | Kenwood KVT-617DVD Car DVD Player
Won't work
Check the A / V input output switch (pictorial #28)) in the rear, it needs to be in the output position. When set to input this disables the splash screen and OSD menu. Musktek manual does not mention this. HTH Linuxdude
Sep 18, 2007 | Mustek MP100 Portable DVD Player
My panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Jan 20, 2007 | Panasonic DMR-E50 DVD Recorder
Mustek V600RZ Theater System Logo
203 people viewed this question
Top Mustek Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
