Question about Whirlpool Washing Machines
Water drains out as fast as it fills........but not all of the time top load Whirlpool
  • 159 Answers
There is a chance the drain hose has buildup within it and needs to be cleared out. This will take about an hour.
Steps:
  • 1- Unplug the electrical cord on the washer from the wall outlet.
  • 2
  • Unfasten the hot and cold water hoses from the water lines after you shut off the water valves. Use a pair of slip-joint pliers to turn the hose fittings counterclockwise to remove them.
  • 3 Pull the washing machine far enough away from the wall so you can comfortably work on the rear of the machine.
  • 4 Locate the access panel toward the bottom left side of the back of the washer. Use a nut driver to remove the nuts that secure the access panel, and remove it.
  • 5 Find the water pump, which will have two hoses attached to it.
  • 6 Identify which hose is the drain hose by tracing it to the outside of the machine. The pump may also be labeled "Inlet" and "Outlet." The drain hose is attached to the outlet.
  • 7 Squeeze the clamp that secures the end of the drain hose to the water pump, using a pair of slip-joint pliers. Remove the end of the hose from the pump.
  • 8 Insert a plumbing snake into the end of the hose and twist the snake as you feed it through the hose. After approximately 10 feet of the snake is fed through the drain hose, you should see the snake and the clog come out the other end of the hose.
  • 9 Reattach the drain hose to the water pump and replace the access panel. Reconnect the water hoses and turn on the water valves. Push the washer back against the wall and plug in the electrical cord.
  • Hope this helps!
    Posted on May 29, 2011
    Whirlpool top loading washer won't fill completely
    did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
    Nov 18, 2017 | Whirlpool Washing Machines
    Whirlpool washer - tub drains while it fills.
    Your drain is to low. Make sure that the drain that your discharge hose is going into is at least as high as the washer. If not the water will drain out as fast as you can fill it.
    Aug 15, 2009 | Whirlpool Washing Machines
    Whirlpool washer fills, begins to agitate, then drains
    Water siphoning out the drain line
    If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
    moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
    Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
    Please leave a solved rating before you sign out
    Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
    Washer Fills/Drains at the same time
    check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
    Dec 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
    Wash Machine Drainage problem
    i am a recently retired appliance engineer of 20 years, slowing down the flow of water from any electrical washing appliances can be dangerous and will cause extensive damage to the appliance in question, at the very least it will stop half way through the cycle every time the only way to remedy this is to rectify the drain, or at least sort out another waste water outlet sorry
    Sep 21, 2007 | Estate TAWB600JQ Top Load Washer
    My washer, while draining, leaks from the bottom.
    remove the panel to observe the drain hoses while machine is in use. using a flashlight, locate the hose that you see leaking.
    May 31, 2007 | Whirlpool LSQ8000 Top Load Washer
    Whirlpool LTE6234D Top Load Stacked Washer / Dryer
    Is your drain hose above the washer tub.. its got to be higher or will syphone out
    Dec 01, 2006 | Whirlpool LTE6234D Top Load Stacked...
    Washing Machines Logo
    49 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
