Question about Honeywell Programmable Thermostat Heater
Error 89 suddenly appeared. I reset the breaker and error message is still there.
  • 1,940 Answers
Error message 89 means "Heating/cooling equipment is missing"
Usually this means that the wiring to the thermostat is not making a connection. This could be a loose connection, broken wire, or failed equipment. You may also want to check the fuse/s to your Outside compressor unit.
You should have an hvac technician test your equipment, wiring, etc. in order to prevent damage to your equipment, and possibly yourself.
Posted on May 29, 2011
While running a program, an error message which says "protected memory violation" was displayed and the calculator stuck and i can't do anything.i cannot close,reset it nothing.can you help...
Application functions cannot be called from within the application. If you try to call a function using the
application's problem-entry dialog boxes, the error message, Protected memory violation, will appear.
Exit and re-enter the application to ensure normal operation.
Jun 12, 2011 | Texas Instruments TI-89 Calculator
Nderstanding the meanung of error messages
There are many reasons a calculator will report an error.
Simple calculators usually only report errors for math operations that are not possible such as dividing by zero or if you hit equals when there is no number between a math symbol ( 3 ++ 4 = ERROR)
For more complicated calculators like the TI-89 an error can come up due to such mathematical errors and there is a lot of room for error with more complicated equations. Also there are programs in the calculator that if not done correctly will crash and cause an error.
The instruction booklet should have a list of common errors and how to avoid them. Look at the table of contents or the index to find such a list.
Good Luck hope this helps.
Mar 11, 2011 | Texas Instruments TI-89 Calculator
What do i do if the error message on my camera appears? (E:91:01) then suddenly spark..,i wonder if it a short circuit or the bulb must be replace?i need some help please..,
TO SOLVE FLASH ERROR sony cyber shot ERROR CODE E:91:01 , JUST GO TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT """"INITIALIZE"""" CLICK OK, MASTER RESET AND IT GOES BACK TO NORMAL. NOTE: DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT YOU WILL HAVE TO SET UP TIME&DATE.
Jan 24, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
May 24, 2010 | Acer Aspire 5315-2713 Notebook
TI 89 when solving equations or integrating a message appears:
With the ALPHA keyboard, Type in the NewProb command and press ]ENTER] It resets the one-letter variables to their default status.
Alternatively, you can use the CATALOG of commands to launch the NewProb command.
Another way is
In HOME directory, press the [2nd][F1] to activate the F6 key. In the menu list, press 1:Clear a-z and ]ENTER].
If you have to use the variable x multiplied by a function (sin, cos, tan, log, etc) do not used implied multiplication: enter the [*] explicitly.
Apr 14, 2010 | Texas Instruments TI-89 Calculator
I was cooking in my Kitchenaid oven and the door locked. It will not unlock
We had the same thing happen
Turn the oven breaker off, then let the oven cool completely. Turn breaker on, there will be an error code appear, push and hold the "bake" button for at least one minute until an error message appears, then press the off button.
This reset the latch on our oven
Nov 02, 2009 | KitchenAid Ovens
Program error
Sounds like you need to reset all associations. Try this fix from Adobe: CLICK HERE.
Oct 25, 2007 | Adobe Photoshop 7.0 for PC
I get an ERROR whenever I try to calculate a Linear Regression.
When you download a program make it is saved to ram and not to archive.
Apr 20, 2007 | Texas Instruments TI-89 Calculator
Heating & Cooling Logo
1,583 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
