Question about Dell Vostro 220 Desktop Computer
My disc won't eject and there's no hole for paperclip.
Some drives the hole is not obvious. Check the crack between the bottom of the DVD tray and the top of the front panel that has the eject button and led lights. There may be a small half moon shaped notch there that serves for access to the internal emergency eject access lever.
Posted on Nov 11, 2011
If your DVD Drive came with the computer originally your DVD Drive should have an emergency eject hole.
Kindly check the emergency eject hole just on top of the eject button you will see there a hole where you can poke using a paper clip.
Posted on May 29, 2011
How do I get a dvd out? the eject button wont eject the disc..
Ah! This is an easy fix! All you need is a bigger sized paperclip or something of that sort. You bend out one piece of the paperclip (a 90? angle) and push the paperclip Straight in the little tiny hole you can see on the disc door or next to the door. It will manually turn the gears to roll out the door.
Jan 26, 2015 | Audiovox ADV45 - 12.1 LCD Overhead Monitor...
How can I eject my dvd when OS is not installed?
The obvious - Use the eject button when the system is powered on.
If that does not work, use a straightened paperclip and manually eject via tiny hole in the front. Works on or off. gl
May 31, 2013 | Dell Alienware Computers & Internet
Why won't my packard bell's cd disc or floppy disc drive won't open
CD / DVD and most optical drives - Manual eject by sticking a straightened paperclip in the tiny hole and gently push open.
Apr 02, 2013 | Packard Bell Computers & Internet
DVD won't eject or play
Use a bent paperclip and insert it into the small hole on the front of the player. This should cause the disk to eject. Reload the DVD and try again.
Jan 25, 2013 | Coby TF-DVD1540 15 in. TV/DVD Combo
The DVD/CD drive won't open
There's a little hole in the front of the dvd drive (it may be behind the flip down cover). Stick a paperclip in the hole while pushing the eject button.
Jan 21, 2012 | ASUS Computers & Internet
Dvd door won't open for Sanyo DVW 6000
If you are trying to eject a disc, look closely at the front bezel of the drive, there is a small hole near the eject button, push a paper clip into the hole (straightened paperclip) and the tray will be ejected.
If the DVD door is stuck and will not open through ejecting via the icon in My computer, or the eject button on the bezel will not work, you likely have a faulty drive that will need to be replaced
Jul 22, 2011 | Computers & Internet
I have an Acer Aspire x1200. Compact "tower". The DVD tray won't open and there is no hole to poke a paperclip into. Is there something else available to me to try? Thanks.
Have you tried right-clicking on the CD icon in the "computer" or "my computer" window? There is an "eject" option there.
If that doesn't work, I would suggest replacing the DVD.
Jun 27, 2011 | Computers & Internet
Won,t eject
I fixed mine by straightening out a paperclip and fiddling it around the small hole in the disc tray cover. Hope this helps
Thanks to ju.c for the solution
Dec 23, 2009 | Samsung External Slim DVD-W USB Compatible...
Dvd drive wont eject the dvd.
find a thin stick but must be verry thin.  you will see a small hole in DVD uniit.  put the stick in it your dvd will eject.
May 29, 2009 | Dell Studio XPS 16 Notebook
Xbox360
Depending on the type of disc drive that you have in your Xbox 360 console, use one of the following methods:
Method A: Insert a straightened paper clip or another small, stiff wire into the first hole from the left side of the disc tray. To release the disc tray, push the paperclip into the hole to press the manual eject mechanism. The manual eject mechanism is a white lever that is visible behind the console casing. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method B: Insert a straightened paper clip or another small, stiff wire into the second hole from the left side of the disc tray. Push the paperclip repeatedly into the hole to turn a gear to release the disc tray. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method C: Insert a straightened paper clip or another small, stiff wire into the into the hole that is directly under the "X3" in the Xbox 360 label on the disc tray to release the disc tray. The hole is located about one inch from the right edge of the disc tray.
In each case, make sure that you line up the paperclip or stiff wire to pass through another notch behind the hole on the console casing.
Oct 17, 2007 | Microsoft Xbox 360 Console
Dell Vostro 220 Desktop Computer   Logo
387 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
