Question about LG LRFD25850 Stainless Steel French Door Refrigerator
My refrigerator stopped working after the power to the home was shut off to replace the outside electrical service panel. When the power was turned back on both the refrigerator and the hot tub were not working. The interior lights to the refrigerator come on when the doors are open however, the external control panel on the dorr does not light and the referigerator does not cool or make any sounds. The freezer does not work and the water dispenser in the door does not work. I have unplugged the appliance and reset the circuit breaker with no results. What could cause this? could this be an internal fuse or the circuit board? What circuit board is used in this model? what parts are needed?
  • rdgillette Jun 03, 2011
    I have purchased the new control board and will be replacing it tomorrow. (This is in a second home at the beach two and a half hours away.) Is there anything else I should be prepared for? Are there any other parts I should buy and have with me incase this does not do the trick? Any particluar tips on installing the board other than ensuring the unit is unplugged? I will let you know tomorrow if this did the trick.
  • rdgillette Jun 04, 2011
    I installed the new board today and everything seems to be working. It powered up and began cooling. On the board I removed the fuse looks to be intact and not burned out? id there something else on the board that might have failed that caused this? I was thinking of removing the fuse on the old control board and soldering in a fuse holder and keeping the old control board as a spare incase this ever happens again.
    Ron
  • LG Master
  • 2,605 Answers
Hello, welcome to FixYa. I just read your post and based on the info provided it certainly sounds like a control board has been damaged. The PCB (main board) at the back is part #6871JB1280P for about $70 at vendors on-line like "repairclinic.com". There is not much you can do short of what you've tried (unplugging) unfortunately. Let me know if I can help in any other manner. Good luck. Regards, Macmarkus :)
Posted on May 29, 2011
  • Mark MacDonald
    Mark MacDonald Jun 04, 2011
    Hello again,
    thank you for replying. I will try to address any questions you may have when you go to install the new control, but it is pretty straight forward.
    I'll just acknowledge your questions from the last post, " Is there anything else I should be prepared for? Are there any other parts I should buy and have with me incase this does not do the trick? Any particluar tips on installing the board other than ensuring the unit is unplugged? " ...the only thing I'd offer is taking a "snap shot" or photo of the board connections to insure they are all the same.
    The main PCB is the power control center basically, so no, you shouldn't need anything further as for getting the unit operational.
    Let me know how you make out or if indeed you have any further questions or concerns and I'll certainly help in any manner I can going forward. Good luck.
    Regards,
    Macmarkus :)
Snowmaster BD60DE keeps on beeping while doors are shut
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 19, 2017 | Refrigerators
Hi, I have a kenmore elite deep chest freezer. Model 253.16582105. can't stop the beeping, even after replacing the 9 volt battery.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Mar 26, 2016 | Kenmore Refrigerators
How do you get the model 370lb to stopping beeping
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Mar 30, 2015 | Refrigerators
Smeg refrigirator keeps beeping without stop
Mar 09, 2015 | Smeg Refrigerators
Keeps beeping without stopping
I turned off the power from the control panel on the door of my frigidaire professional series side by side and now it wont power on, its just saying OFF. what should i do?
Hello Mark;
My name is Peter. I am a retired field service refrigeration technician.
You do not give me much to work with. A model number would help.
1.) Why did you turn the power off? A electrical storm?
2.) Refrigerators are like computers, some times you have to reboot them. Unplug your refrigerator for 10 minutes to let the system completely shut down. Plug the unit back in.
If the reboot does not work contact me, either 'E' mail goodwinpeg@aol.com or phone: 443-306-1362.
Oct 29, 2014 | Frigidaire Refrigerators
Flap won't stop humming buzzing
Oct 07, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
How do I get my refrigerator to stop beeping
Sep 10, 2014 | Samsung RF4267HARS Stainless Steel French...
I have a goodman gsc13 ac unit about 4 year old. When the temp gets around 90 or above outside the fan on the unit starts but the compressor does not. I had service check it out but that day they were...
It sounds like the unit may be over charged. Make sure the outside coils are clean and you have plenty of airflow coming out of the top of the outside unit. What could be happening is, when the temps get higher outside, so do the pressures in the system. The compressor has a thermal overload protection that will kick the compressor off if it gets to hot, which if the compressor is over charged, it will work twice as hard, over heat and shut off. You would need a technician to come out and get the refrigerant charge back to normal. Another thing that could be happening is a weak or faulty capacitor, which is a small round or oval metal object, found in the electrical compartment on the unit. This are fairly simple to change out if your comfortable with electric. I've also had to put what's called a hard start kit on compressors with the same problem, new and old. The hard start basically gives it that extra boost of power to get it up and going. I would start with the refrigerant charge and go from there. The electrical "humming" sound that you hear unless you turn the breaker to the furnace off, is the contactor on the outside unit having a call for cooling. The 24 volts come from the furnace, to the outside unit, and pulls the contactor in to power the unit with the 220 volts supplied. It is normal and you don't have to worry about that at all. I hope some of this helps and good luck!
Jul 05, 2011 | Heating & Cooling
LG LRFD25850 Stainless Steel French Door Refrigerator Logo
126 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
