Question about Remote Start System
Viper 150HF in a 95 chrysler New yorker. We have no fob and the car will not start (Turns over but no spark) what is the best way to get the car running again?
  • tim_lenz May 29, 2011
    I have unplugged the unit and the car still will not start
    I just pulled the plugs off the alarm box. Is their actual cube relays under the dash that work with the alarm modual
  • 2,926 Answers
When the unit was unplugged, were the original connections for the wiring connected back to their original factory locations?
Posted on May 29, 2011
  • 4,472 Answers
Honestly I would just remove the viper system or have it removed by a sound/alarm specialist. Shouldn't cost much to have it removed.
Thanks,
Lee
  • Lee A.
    Lee A. May 29, 2011
    Did you just disconnect it or did you reconnect what will need to be reconnected after removing some of the wires? Here is a helpful write up:
    http://www.ehow.com/how_8006415_remove-v...
    Please reconsider and accept/rate my solution accordingly.
    Thank you,
    Lee
  • Lee A.
    Lee A. May 29, 2011
    Just pulling plugs won't work. This is a go between a lot of components in your vehicle. It tells what to work when. Like the ignition when to work etc. Your best bet is to just call your local alarm place and they can remove it and put everything back the correct way. You may not want to go messing with wires if your not sure what to do as you could do damage that isn't easily reversed.
    Thanks,
    Lee
95 chrysler new yorker, car starts for 2 to 3 seconds and stalls, headlights flash off and on and turning signals flash, how do i fix it?
I owned a LHS and 94 New yorker both cars did this, have the door locks checked for a loose wire for the alarm system, something is telling the security system there is a breach, you must lock the doors, shut the door and then open the car door by unlocking it with the key or it will continue to do this. Mine had loose wires and the door lock would not sense the key so I used the passenger door in the same way I described above. IT will NOT Start and run if this is an issue until the alarm is reset by doing as I described. Good luck BTW both cars suffered from failing transmissions, very weak trans in these cars.
Jul 30, 2014 | 1995 Chrysler New Yorker
My 95 new yorker that was running when i shut it off and then wouldnt start again?
Bad starter or possible poor battery cable or starter cable connection.
May 13, 2012 | 1995 Chrysler New Yorker
1993 New yorker turns over but will not run more than a few seconds
I would change the fuel filter and if that is not the problem then check the fuel pump. If that isn't it make sure you have spark at the plugs.
Aug 14, 2011 | 1993 Chrysler New Yorker
I have a 95 chrysler new yorker the fans faulty.
try checking fan motor to see if is good take it of and use battery to make them work if that dont help motor is bad
Apr 08, 2010 | 1995 Chrysler New Yorker
1986 NEW YORKER TURBO TURNS OVER ATTEMPTS TO START BUT WONT RUN HAS SPARK
you need to check the fuel pressure on the rail it seems too low
Jan 26, 2010 | 1986 Chrysler New Yorker
Will not start
is it a carby model?check fuel filter,fuel pump drainfuel bowl,do you have spark?check wires
Jan 06, 2009 | 1984 Chrysler New Yorker
89 Chrsler New Yorker Lebaron won't start
possibly the fuel filter. Try taking of the battery cables and resetting the computer
Sep 07, 2008 | 1989 Chrysler New Yorker
Starting problems on a 1995 new yorker
Could be a few things. You said starter works, does it turn the car over or just whine?
If the car is turning over it could be a spark of fuel problem. Check your spark plugs, fuel filter and get your pump tested. The fule pump can be heard working when you click you car to the "on" postion, you will hear a buzzing sound. Try leaving your car in the "on" position for about 30 secs, then try starting it. I would also get your battery tested as there may not be enough power getting to the starter to fully turn the flywheel.
Jun 15, 2008 | 1995 Chrysler New Yorker
Remote Start System  Logo
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
