I have a Clarion DRX6575z in a dodge Dakota 2001. I removed the factory stereo and put a wiring harness on the clarion and installed it. The stereo worked fine until i turned off the truck, and when i turned it back on the light would not work but would still play. i woke up the next morning and it came on again with no light, went to put in a cd and now the stereo wont work at all. i then tried to put the old stereo back in but it would not work either. i proceeded to check the fuses and nothing is blown that i can see. WHATS WRONG? -Desperate for music-
Check all the connections with an analogue multimeter set to 12 volt dc.You should get fsd at all points. There is no doubt that you have an intermittent fault on the wiring.However, there is a slim possibility that this fault may, in turn, have caused damage to the clarion.If you cannot find a fault on the wiring, then consult a repair manual (available to download) to see whether or not there is a fuse inside the clarion. If there is one fitted, check that to see if it is blown. If thate above does not sokve the problem you are welcome to email me for further help on [email protected]. But I think fokkowing the above advice shoukd solve you lack of sounds in your car. All the best
