Question about Sony Televison & Video
Our Sony Bravia kdl-40W3000 turns on very briefly and then shuts off, and there are no blinking lights. Does this tell me anything?
Want to sell it to me
Posted on Apr 18, 2013
  • 4,889 Answers
Does the LED atleast stay in standby mode after it shuts off or does it go off altogether. It sure sounds like a protection fault causing the relays to power off the set but I would like to get as much info as you can give me to zero in on the source of the problem.
Posted on May 29, 2011
  • 6 more comments
  • mmckitri May 29, 2011
    I press the power button on the remote, there's a click, the green LED comes on, after a few seconds the red LED comes on (and it might flicker a bit, but it doesn't flash); the picture comes on briefly (and I hear a slight buzzing sound) and then the TV goes off and both LED lights go out completely. It's not in standby mode. And after doing it a few times I smell a smell like a hot component. So something is drawing excessive current. Thanks so much - Mary
  • eagle338
    eagle338 May 29, 2011
    Indeed. There is only one way to figure this out since there is no blinking. We should start with the 5V line of the power supply board as there is no standby light. Do you know how to use a multimeter?
    yes am taking the back off now - thanks so much for your help. Will report back shortly.
    Taking the back off was tricksier than anticipated. So, there was arcing in the high voltage area. Wires between the LED panel and the high voltage area passed over a connector - don't know if it was the connector blades that weakened the wires, or if there's something on the other side of that connector that is a problem - don't have a schematic. Going to repair the wires and see if that fixes the problem. Many thanks - Mary
  • eagle338
    The arcing suggests that either the backlight inverter is faulty or the load balancer circuit of the panel is faulty. Let me know whats the status after you fix the connectors.
    It was arcing because the wires were severed. I think what's faulty is the design. Anyway, the wires are spliced and soldered and the TV works, so we'll call it good for now!
  • eagle338
    Glad to hear that!
  • Orlando Gomez Jul 13, 2011
    Hey, I have the same problem. I noticed that the standby LED is always blinking eight times. I bought that LCD as an "Open Box Sale" in Sears (McAllen, TX) 3 years ago, but I didn't use it so frequently.
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony kdl-32s4000 goes on and imidetly go off
When it goes off, you should get some kind of blinking led. How many time does it blink befor it pauses and starts again?
Mar 20, 2013 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Kdl-40w3000, when power button pushed, tv comes on for a few seconds then shuts off then standby blinking light comes on 13 blinks, pause,13 blinks pause, etc
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise,
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this will to fix the fault......
May 29, 2011 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Tv turns on and immediately goes off. then the red blinking light comes on which the book indicates it needs service. upon calling a tech he tells me the lamp is out. but I can find a panel and...
Have you got the right model number this is an LCD TV, not a back projection set which uses a projection system. There is no bulb to take out on this model number.
Feb 07, 2011 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
My KDL sony tv turns on briefly(displays menu) then shuts down, and standby led flashes 6 times then pauses then continues, does not respond to the on/off button or the remote
6 times blinking standby light indicates problem with Audio Section in tv
Check AU 15V output of G2 (power supply) board then check AU board as it has sound processor and sound output ICs.
If you are not familiar with electronics stuff repair then call local tv repairman to repair it for you.
Thanks.
Oct 29, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony kdl-40w3000 does not turn on. Standby light blinks 13 times. What is the problem
sony kdl-40w3000 does not turn on. Standby light keep blinking. What is the problem
May 04, 2010 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Sony bravia 46 shutting off a blinking 6 times
here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Sep 11, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Wont turn on
It is back light inverter board failure error. Check back light inverter board in TV.
Aug 08, 2009 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Goes on for about 6 seconds and shuts off goes into stand by
Do you see standby light blinks? if yes, please count it and let me know.
Jul 23, 2009 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Televison & Video Logo
244 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
