Question about U-Line CO2075F-B Echelon Refrigerator Ice Maker Combination
Ice maker frezing at storage tray and door will not let ice in shoot
I have a kenmore refrig. was in the house when i bought it. the ice maker works for two or three daays after i clean the frozen ice from the storage tray and from the door. after that it freezes up again and i have to dump the ice and thaw the door again. i have called and asked kenmore,they wont answer any questions, will send someone out for a fee. rally need your help
    Habit-Forming:
  • 30 Answers
This is generally caused by one or two things (sometimes a combination of both).
1.) If it is a "frost Free" freezer the mechanism that partially thaws the freezer has stopped being regulated and will require professional repair.
2.) The door gasket may be bad, causing a small amount of warm air to reach the ice and then it is refreezing in a blob.
another cause is: if you constantly open the freezer door or hold it open for long periods of time while searching for items etc. the ice lightly skims with moisture then refreezes into a blob.
Posted on Dec 16, 2008
SOURCE:
Kenmore refrig model # 10645423801 cannot remove ice storage bin
Could it be frozen in? If so, u may have bad door seal or ice door seal is not shutting properly.
Nov 04, 2017 | Kenmore Refrigerators
2014 Kenmore side by side refrig. Water comes out of the door fine. Will not make ice.Tried the reset button on the left by the bucket, took top of door apart to see if mechanism was froze up.
Hello Rhonda Cornett,
Okay... water at the wall is connected... good...
but now you have TWO solenoids at the ENTRY POINT...
It would have been nice to know if there is water in the tray...
or if it EVER WORKED... but whatever.
If you are NOT getting water in the ICE TRAY...
you need to check that wire is connected to ITS OWN SOLENOID... (ELSE: solenoid might be bad)...
You might be able to TEMPORARILY REVERSE the water valves
to see if the door service still works with the SUSPECT VALVE..
Still works ... Ice maker trouble...
Fails solenoid trouble (bad valve) replace!
Then restore EVERYTHING... (take pictures ahead of tampering).
That click (or thump) you hear whenever you fill your water glass.
Every ice-maker I've ever tampered with has an on/off switch..
Fill controls... and firmness settings of some sort...
Check'em all out before getting DRASTIC.
Not the correct ICE MAKER PARTS
(illustrative purposes only)
appliance part houses (sears = pricy (IMLTHO)).
Water Filters Lawn Garden Appliance Parts
Jul 08, 2016 | Kenmore Refrigerators
My kenmore elite refrig keeps leaking water from what appears to be condensation. It gets so bad that the ice maker door freezes shut and water actually drips on the floor. The freezer is set to 0 while...
The high level of condensation is due to constant opening of the fridge when the frost develops. It is required to defrost off the condensation and if this has an auto mode timer for defrost , then it is possible that it is not working.
The water must drain out to the drain tank but since it is formed out of the freezer the water flows out of the collection tray.
Sep 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Dec 30, 2009 | Kenmore Refrigerators
Water not comming to ice maker
Ice maker is fixed. We unpluged the frig for about 10 minutes and it is now working. Someone else was given this as a solution from FixYa and it worked for me. Thanks
Nov 22, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore elite french door freezer on bottom
Odds are due to the fact the ice maker was left on for an extended time with a full tray of ice the mechanisms froze. You can take a hand held hair dryer and defrost the parts, just be careful not to get too over zealous and melt the plastic parts. It should only take a few minutes to defrost.
To avoid this problem from occurring again, I turn the ice maker off when the ice tray is full.
Regards,
Ann
Nov 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker problem
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Oct 03, 2008 | LG LRSC26940ST 36" Side-by-Side...
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
214 people viewed this question
Top U-Line Refrigerators Experts
Elie Balas
Marvin
Marvin
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
