Question about Hayward H-series Electronic Gas Pool Heater H400
My pool heater flashes LO and BO. - Hayward H-series Electronic Gas Pool Heater H400
  • Hayward Master
  • 1,631 Answers
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
  • enough water in pool or spa?
  • If you have a weir gate in skimmer, is it stuck in the UP position?
  • Are any valves closed?
  • Do you have a bypass valve at the heater?
    • If open, this will reduce the amount of water going thru heater, close it to the point, LO goes away.
  • Could be debris in front of Pressure Switch, in the copper tubing
    • Unscrew and remove pressure switch, turn pump on. But first, align end of tube so that when water squirts out it will shoot out from heater and not onto electronic heater components!
  • If all above is good, you may have failed pressure switch?
  • Etc
BO Message...
This means "By-Passed Operation"
This mode is for systems with 'Automation' controls. If you don't have an automation system, then your heater has a control dip switch or logic jumper that needs to be undone. But if you have automation, do Nothing, your automated system has control of your heater. Good Luck - hope this helped.
Posted on May 25, 2015
  • 5 Answers
SOURCE: Error code LO
Is the heater installed indoors?? if so you'll need a vent pressure orifice kit.
if not check your water press. (below 18 PSI on filter) Place filter on "recir" if it fires and stays on . it's the pressure.
check to see if all connections a set tight hi-ltd switch wire harness etc.
Posted on Jun 07, 2009
  • 139 Answers
SOURCE: hayward pool heater c4205 has error message of LO
lo usually indicates insufficient water flow and/or pressure switch malfunction.make sure filter is clean and pressure is in normal range
Posted on Jun 21, 2009
  • 128 Answers
SOURCE: same problem pool heater shows hayward pool heater bo error
BO means that you have bypassed operations. ie automation. if no automation is present then press and hold the Down arrow and Mode button for 3 seconds.
Posted on Aug 23, 2009
  • 246 Answers
SOURCE: my pool and spa heater is not working diplays
MAKE SURE THE FILTER IS CLEAN THAN THE TEMPETURE SENSOR MAY BE BAD, CLEAN THE FILTER FIRST
Posted on Oct 13, 2009
  • 4 Answers
SOURCE: my hayward heater gives a LO error when trying to
One of your limits is not working or not wired up. An easy way to check the limits - Water pressure switch, Hi limits, air pressure switch all of which have 2 wires going to them. Unplug one item and connect the 2 wires together ( paper clip works fine ) Then retest, if problem does not go away remove paper clip and reconnect wires and move to the next limit. The limits are located in the black plastic header. Always make sure water is flowing through the heater at all times while checking the limits.
Posted on Mar 01, 2010
Had a power outage yesterday now heater won't ignite. No error codes.
bo = 'Bypassed Operation'
heater is now controlled via your automation system.
Create a heat call, turn solar off if active.
Heaters should be set to auto on.
Mar 07, 2015 | Hayward Pool Products Hayward Universal...
Hayward h series Bo problem
make sure you have adequate gas pressure
May 17, 2014 | Hayward H-series Electronic Gas Pool...
Can't get pool heater to work
low pressure check filters or pressure switch
May 03, 2013 | Hayward 250 1 Millivolt Propane Pool...
"bo" when turns on then goes to service and shows
Bo means bypass operation which means the heater is being controlled by an outside control. There are 2 togs on the back of the board that control this function
Jun 19, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
H400IDL Hayward Pool Heater. Ours is dead. Any suggestions on what we need to do to fix it? FS, BO are our error messages.
BO is bypass operation fault and FS is temp.sensor failure. It is recommended that you contact a pool professional to fix this. If you are in the Phoenix Metro area you can contact me at info@wefixuglypools.com
Dec 28, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Flashing LO
"LO" means a "Limit string open error" has occurred. See the owners manual for the many causes and possible solutions. Owners manual found here. http://www.haywardnet.com/products/Manuals/pdfs/Manual225.pdf
Apr 08, 2010 | Hayward 350K BTU H SERIES HEATER DRAFT...
Same problem pool heater shows hayward pool heater bo error
Aug 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward pool heater c4205 has error message of LO
Jun 20, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H-series Electronic Gas Pool Heater H400 Logo
153 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
