Question about Dryers
I have an lg dle7177wm dryer - i'm trying to get to the heating element to check for a circuit and am having trouble figuring out how to get the dryer apart
  • 706 Answers
Try this approach.. with the dryer situated so that you can access the back of it.. look at where the top cover projects over the back..directly beneath that is 3 screws that when removed ,..should allow you to slide the top back and release it from the chassis.. Once that has been done, you should be able to remove the front panel ( after you undo the lint trap screws with the door open ).. You can tilt the front panel away from the cabinet to unhook the door switch.. than you should be able to lift the front panel assembly up and off the guides on the bottom.. Once it is set aside, you should have access to everything you need from the front.. Hope that helps...
Posted on Aug 16, 2008
Where is the reset button?
There is no reset button, the issue is most likely a heating element
Feb 02, 2015 | LG DLE7177WM 7.3 Cu. Ft. Electric Dryer -...
Dyer will not heat
Sounds like an open heating element issue. If you have two sensors for internal temps, the chances of both going bad at same time are remote.
Locate the element wiring and disconnect from circuit and do a simple continuity test. Chances are that it is burnt out or open.
Jan 28, 2014 | LG DLE7177 Dryer
LG DLG2532 dryer not heating up, lint trap clean, good air flow out exhasut vent, all controls seam to be working i.e. lights on buttons and chimes good, seams like its not getting gas but valve is turned...
Hi, Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Apr 16, 2010 | LG DLE2532W Electric Dryer
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
Dryer does not heat up/ dry clothes
sound like heater or stat call them out.
Sep 28, 2009 | LG DLE7177 Dryer
2008 LG Dryer will not heat.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
Dec 11, 2008 | LG DLE5977 Stainless Steel Electric Dryer
I just moved and my LG dryer does not heat up.
Heating element
Thermal fuse
Wiring
Dec 01, 2008 | LG DLG5932W Gas Dryer
LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Aug 27, 2008 | LG DLE2532W Electric Dryer
Dryers Logo
218 people viewed this question
Top Dryers Experts
