Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Model RY30040A I replaced the pull cord and reassembled the unit but now as the engine runs the shaft does not turn... The clutch bell housing seems to spin freely so did I not assemble the clutch correctly? I tightened the clutch plates but did not torque them too hard. Any Idea's? Thanks, Mike
  • Mike May 29, 2011
    The shaft is not broken in the tube. It has something to do with with the clutch or clutch bell housing as far as I can tell. I can insert the bell housing into the tube and activate the tube (to spine) by hand.
  • Mike May 30, 2011
    Got it! The clutch wasn't adjusted properly... so I dug back into it, corrected the problem and am now ready to get those weeds!
    Thanks!
  • 2,510 Answers
The flex cable has squares pressed into each end which you no doubt noticed. These squares must engage the drive on the motor side and on the cutting head side. It is possible to assemble the unit with the flex cable lying to one side and not engaging the drives, top or bottom. Strip the shaft and tube assembly again and check the drive ends, also check that the flex drive has not sheared.
Posted on May 29, 2011
  • Hans Pearson
    Hans Pearson May 30, 2011
    It sounds like you are talking about the centrifugal clutch. There are two flyweights that are motor driven and centrifugal force throws them out as the motor speeds up to a bit above idle. The weights are spring loaded to the retracted position. The flex cable is driven by the drum when the flyweights drive it. The flyweights have a friction lining on their outer surfaces which drive on the inner side of the drum.
  • 252 Answers
Yea man the shaft is broken somewere in the tube
How to remove 1400 Nissan gearbox out
1 Remove battery earth cable.
2 Remove gear shift lever - usually just pulls out.
3 Remove starter motor.
4 Remove bolts holding prop shaft to gearbox final drive, and remove the prop shaft.
5 Remove all bolts around bell housing holding bell housing to engine.
6 Slide gearbox back to slide spigot shaft from clutch plate.
7 Slide gearbox from under vehicle.
Gearbox is now removed out.
Jan 02, 2015 | Nissan Cars & Trucks
Craftman weedacker
  • Hole in the end of the clutch housing where the cable slides in has a # 20 torx screw in there.
  • Pull the spark plug, stuff some rewind starter rope in the plug hole, use a water pump pliers and turn off the clutch plate(s). NOTE: curved shaft trimmer will be a standard right-hand thread, straight shaft will be a left-hand thread.
Oct 04, 2008 | Craftsman 25cc Gas Line Trimmer
How do i drop the trans
Remove the Rear Drive Shaft
Remove the Transfer case if 4x4
Disconnect the Shift
Disconnect the Clutch Secondary
Floor Jack under the Transmission
Remove the Cross Member
Remove Bell House Bolts
Pull straight Back
Lower Down
6 Pressure Plate Bolts
Remove 6 Flywheel Bolts
*(Recommend replacing Rear Main Seal)
Resurface Flywheel
Reassemble
Apr 15, 2013 | 1991 Ford F250
Removing bell housing
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 10, 2012 | Daihatsu Rocky Cars & Trucks
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
Feb 02, 2012 | Homelite Garden
Change pull cord
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. 11
Jan 27, 2012 | Homelite Mighty Lite Lawn Trimmer
How do you remove the clutch so that the pull cord can be replaced
Dec 31, 2011 | Garden
How to fix my echo gt200r gas trimmer I was trimming with it and it got hook on a vine. Then when I engaged the throttle it spun for a second and then stopped, tried a couple more times and it did the same...
remove the head from the shaft( tube) and remove the broken drive cable
get and fit new cable and then reattach the head to the shaft ( tube )
the gears in the head are fairly robust but the drive is a cable which twists up and pulls out of the drive squares at either end
Aug 02, 2017 | Echo Garden
Replacing pull cord on troy built mower model # 8654r 4hp
Remove the housing covering the clutch. The cord spool can then be accessed. Replace the cord. Be careful that you maintain the proper spool spring tension. Check operation before reassembling
Jan 10, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
The pull cord on my Ryobi 30cc trimmer broke. Is this true, that there is no way to access case to replace the pull cord? This has been my difficulty! There seems to be no way to reach clutch springs,...
If you have the same kind of clutch as my cs30 week wacker, then there is a screw at the end of the shaft that the clutch sits on. The screw is down inside and requires a star shaped screw driver to turn. When I tried to turn it, the engine kept turning. I had to open the back part of the engine in order to put a screw driver in it to stop it from turning.
May 19, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
217 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
