Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Won't do anything
My Whirlpool Cabrio washer keeps reading LD and won't restart or nothing. It has water in the tub. I tried unplugging it and starting over, but it won't do anyhying. will not spin drain or do anything. Have plugged back up when i try to restart it puts water in the tub and does nothing. when i hit cancel the control panel locks up and i have to unplug to restart it. what do i need to do
    Genius:
  • 1,028 Answers
Try to remove as much water as possible ..wet vac will help pull unit out remove back cover lean washer forward on left bottom is drain pump remove 3 screws holding pump and clamps holding hoses on pump..on motor side of pump are 4 screws remove them noting location and orientation of pump body clean out ..ck impeller ..round white part with fins ..if it is not broke try turning it by hand should turn but with some resistance if free wheels replace pump if you found stuff in pump reinstall and ck
Posted on Aug 16, 2008
I have a whirlpool Cabrillo model and we paused the cycle with the tub full of water and it will not restart after more than twenty pause/cancel tries, we have unplugged it and tried. moved the cycle from...
Brent60, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Brent60), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 23, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer has ld code. have checked pump as well as inside the washer by taking basket out & nothing is plugged up. there was a small amount of water in drum when we removed basket....
Please see the following Whirlpool service manual for the Cabrio washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96˝ ?
• Is the pump running? If not, see TEST #7.
Oct 20, 2009 | Whirlpool Washing Machines
Keep getting LD error code on whirlpool cabrio washer
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Mar 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Jan 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio Washer LD error code
Oct 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't do anything
This is another possible solution, more than likely most people will expierience clogs. I had the same problem today, upon removing the drain pump I noticed one of the dark blue wires was off of the connector that plugs into the pump, seems these are held in place by a "splice connector", and is a simple fix, after you unplug it from the drain pump take the connector and pull from the front and rear to open the splice jaws, re insert the wire and push back together. Plug it back into the pump, and that's it!
Dec 30, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
261 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
