Question about CDV Software Blitzkrieg: Rolling Thunder for Windows
Rolling Thunder will not run on Windows 7 - CDV Software Blitzkrieg: Rolling Thunder for Windows
  • 122 Answers
Run it in compatibility mode by right clicking on the rolling thunder icon. And then click on Run it in compatibility. Let me know how it goes.
Posted on May 29, 2011
How do you remove the muzzle brake
Don't! That barrel's actually a highly desireable item....keep it intact! If you want to go without the muzzle brake, just switch the barrel. Hit Ebay or your next gun show. You can get barrels for the $50-75 all the time of the day.
Jun 10, 2014 | Mossberg 500 Rolling Thunder 12-Ga Pump...
Please help
Change the compatibility settings of the .exe file that executes the game to an earlier o.s. That should work. If it is REALLY old, try DOSBOX
Apr 16, 2014 | CDV Software Blitzkrieg: Rolling Thunder...
2002 Yamaha yzf 600 rpm stays hi when reved
Hi, Anonymous and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Motorcycle revs stay high after rolling off throttle motorcycles
YZF600R Idle Problem Rev Problem
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
Sep 08, 2013 | 2002 Yamaha YZF 600 R thunder cat
Black screen in windows 7?
most probably a driver issue with your video card see if you have the right driver for your video card window 7 requires latest drivers especially running 64bit, but if this is a fresh install of windows 7 try rolling back to xp and see if you have the same problem
Jun 18, 2012 | Computers & Internet
Toshiba a25-s2792 No sound in windows 7
Yes,....good Ol' Windows updates. Known to knock a system partially out of commission.
Windows has lost the address to the Audio drivers. The reason it states Audio is working properly, is because Windows is full of it.
The Toshiba Satellite A25 series of Notebook PC's, did not come with Windows 7. It came with Windows XP. You, or someone else installed Windows 7.
The updates knocked the audio driver address file to the curb.
All you have to do, is install the Win7 installation disk again, and perform a Repair.
(Non-Destructive Installation)
OR, use the Restoration Disk, (Backup disk)
Toshiba eSupport does not provide audio drivers for Win Vista, or Win 7, for this model. Only Win XP,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=665687&rpn=PSA20U&modelFilter=A25-S2792&selCategory=2756709&selFamily=1073768663
Regards,
joecoolvette
{Do I think going to Device Manager, and rolling back the audio driver, or upgrading it, will help? NO }
Feb 12, 2012 | Toshiba Satellite A25-S2792 P4 3.06GHz...
When i install the game, the graphics of the cars are all distorted. how can i fix this? I'm running it on windows 7. Will it have problems running on windows 7?
Right click on the executable file for the program, select Properties. In the resulting window, select Compatibility, then change it to Windows XP.
To find the executable, right click on the icon and look at where it says the shortcut leads, then navigate there in Computer Explorer.
You might also find a config utility in that folder, or in the options menu.
Jul 05, 2011 | Electronic Arts NASCAR Thunder 2004 for...
When I turn on my acer netbook a message comes on that says a recent hardware or software change might have caused windows not to start successfully.
It sounds like a software or driver problem.
You could try running Last Known Good Configuration and see if rolling back to a known good will work.
This video will help you to run last known good configuration, it shows Windows 7 but if your not running Windows 7 all the versions of Windows run last known good config in the same way.
Jan 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
I am thingking of getting a Thunder K8WE (S2895)
Hi!
Of course it can run Windows Xp 32 bit. The computer specification is much higher for the operating system to run and there can be no problem for it.
About the hard drive, it depends upon it RPM (Rotate Per Minute) and it's data access time. I think SATA drive is good to use.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 04, 2010 | Tyan Thunder K8WE Motherboard
CDV Software Blitzkrieg: Rolling Thunder for Windows Logo
1,005 people viewed this question
Top CDV Software Video Game Consoles & Games Experts
James Wishart
comandomcl8
Level 1 Expert
Bill Boyd
Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
