Dish tv s7070 not working correvtly, able to get sound but picture locked, unit either shows 'boot' on display, 'p' or 'p002' remote will not work and have to turn off at power socket, display also has green lock light illuminated when 'p002' is displayed
  • 8 Answers
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Posted on Aug 21, 2008
dsacco86
  • 1077 Answers
SOURCE: power light keeps blinking green with no display
I would try leaving the TV unplugged for 30 minutes to let the TV reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
  • 257 Answers
SOURCE: Screen is black even though the green light is lit
Tv has power supply board inside defective. This board needs replaced.
Posted on Aug 18, 2009
  • 92 Answers
SOURCE: westinghouse 30" lcd tv has no sound no picture,but green lighton
Replace the Power Supply.
Posted on Sep 06, 2009
  • 8457 Answers
SOURCE: power light blinking green and cannot turn off or display anythin
power inverter board is dead.
need a new one.
Posted on Sep 14, 2009
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
Display not working
1) test the power supply for LED Displays.
2) Led Displays faulty, repair.
God bless you
Jul 06, 2012 | DISH Network Televison & Video
I have DISH NETWORK & something happend so whatever is on in 1 room appears on my TV that I dont like how can I control ONLY my TV & fix this problem?
Brandonhusse,
It sounds like the receiver is in single mode, which will allow both TV's to show the same picture with 'Shared Viewing' enabled. On the front of the receiver should be a 'Mode' button. Press that to change it from Dual to Single or Single to Dual. The orange light on the front of the box will let you know which one it is on.
Once changed to Dual mode, try the TV's again and see if they are functioning separately. If the problem continues, let me know here or at thomas.faust@dish.com!
Tommy Faust
DISH Social Media Representative
Jun 25, 2012 | DISH Network Televison & Video
I can't get a picture to come up.
Have you gone into your setup menu on the satellite and changed any display settings? My 60" HDTV was doing similar things and i was not able to use picture format on my controller to get fom zoom to wide screen, and so on. I had to go into my dish menu and go to setup then video and adjust some settings to display the TV resolution ratio. I was not in the HDMI connection menu when the new TV was origianlly installed to my DIsh. Also had to do same thing on my PS3 under settings and video output resolution.
Just a thought!
May 29, 2012 | Panasonic PT-AX200U Projector
I'm hooked up tp Dish Network an hit wrong button on top for volume and now pic is gone. in lower left corner says no signal., but dish is working, just no picture on screen
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to change your TV back to the proper input or channel. If the TV remote is not working to change the channels you can also use the buttons on the front of the TV. First look for a button listed as either input, TV/video, source or AUX. When you press this button it will start cycling through all the inputs available, make sure to cycle through them slowly because it make take a couple seconds for the picture to come in. If you do not find a picture on any of the inputs you are going to need to try the different channels. Normally for a TV where the receiver box is the TV should be set to channel 3 or 4. Once you have found your DISH Network picture you will want to make sure to push the SAT button on the DISH remote so that it doesn't change the TV channel again. I hope you find this information useful and if you have any further questions or concerns please let me know. Thanks. :)
Oct 22, 2011 | Craig CLC501 15 in. TV
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
Unit is on Dish Network. Timed out during nite. "Locked" message on. Experimenting with remote was usless. No picture. Unit is small flat screen. Gift, no manual.
First, power down the Receiver and remove the card, disconnect your dish networking data cables. ( All )
Power down your TV.
Allow 2 minutes for the dish receiver to set, before powering up.
Next, reconnect all cables to dish Receiver and power on the TV and Receiver.
Next, plug in the card for Receiver.
The unit should cycle and show network accessing satellites.
If you have used this system before, you should know any setup steps or configurations.
Hope this has been of some help and your system now works.
Please rate kindly.
Nov 17, 2009 | Televison & Video
Tv has sound but no picture.
If it works on DVD but not on your Dish, and when you connected it to another house it had the same problem then it sounds like your input connection is bad on the TV. That is if I am understanding this right. From what I am reading your Dish network is not showing a picture but the audio is working fine. The DVD player works fine on the TV though. Then you took the TV and hooked it to another dish system and it was the same problem. That sounds to me like you TV is having a problem, either that or the cables for your Dish network are bad. Try switching to a different input, like the one the DVD player is on and seeing if it works there. If not, then the cables are bad and you just need to replace the cables. If it does work though where the DVD was working before then your TV input is bad on that port you were hooked to before.
Let me know if you have any other questions and if this was helpful. If you need some more clarification let me know, I hope this is helpful. Good luck and have a good weekend. Get it fixed before the Super Bowl.
Jan 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No Satelite Signal Indication
The "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to. If the unit works then the problem is the supposed defective unit, if the unit does not work then this denotes a possible cable problem. Tell me if this works for you?
Sep 25, 2007 | RCA DRD485RG DirecTV DTV Receiver
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
