Question about Troy Bilt 5.5hp Self Propelled Mower
What length belt does the 21 inch Troy Bilt 650 series self-propulsion lawnmower take?
landsend
  • 1066 Answers
SOURCE: Troy Bilt Self Propelled Lawnmower drive belt
belts usually come off for a few reasons.
They become loose...stretch or the tensioner moves,  Make sure that none of the tightening bolds are slipping.  You can dab them with a bit of paint.
when the pulleys are not in alignment or crooked or bent.  Eyeball the path from one pulley to another, also make sure the tensioner is in alignment and there are no other obstructions.
good, high quality belts are required, and they must be real drive belts...not regular v belts.  If there is a way to watch the belt in operation you can usually see what's going wrong.
On my lawnmower I had to grind some metal away where the belt went from the motor to the transmission.  Good luck
Posted on Apr 18, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Posted on Jun 05, 2009
  • 11 Answers
SOURCE: Troy Bilt Self Propelled quits running also
clean out the float bowl on the carb sounds like you have gunk in the carb
Posted on Jul 23, 2009
  • 553 Answers
SOURCE: how do I go about geting a manual?
Go to the site listed below, in the search box enter "manual and your model, this should come up with a downloadable manual.
http://www.troybilt.com/webapp/wcs/stores/servlet/topcategory_10001_14102_-1#
Posted on Jul 20, 2010
vincob
  • 718 Answers
SOURCE: variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Posted on Jul 26, 2010
My Troy-Bilt TB330 163cc 21-inch 3-in-1 Rear Wheel Drive Self-Propelled Lawnmower will start and run for a few seconds then stops. Why
sounds like a fuel problem. check to be sure the air filter is clean. if it is you may need to take the bowl off the carburetor and clean it. or maybe even take the car off and clean really good. over time dirt or debris even water will plug up the jets inside and cause it to do what you are saying.
Apr 08, 2017 | Troy-Bilt Garden
Why does oil and gas come out of air filter on a troy bilt model 725 ex 21 inch self propelled lawnmower.
You haven't recently had the mower on its side have you? If not you may have a valve or valve timing problem.
Aug 24, 2014 | Garden
How to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Nov 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Troy Bilt 675 Series manual
Try internet search w/full detail like you used in question plus specifics like model number. That worked for me w/my lawnmower manual search.
Jul 09, 2012 | Garden
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Troy Mower Belt Slippage
If you have an tension adjuster on the handle loosen up until you can slip it back on. If thats not enough remove the spring at the tranmission.
Jun 10, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Need replacement belt guard for sovereign lawnmower
  1. Discount Troy Bilt Partsupstateoutdoorpowerequipment.com Save Up To 35% on Troy-BIlt Parts. Save Up To 35% on Troy-BIlt Parts.
  2. Troy-Bilt Partswww.partstree.com/troy_bilt_parts Need Troy-Bilt Parts? Look Up Parts and Diagrams for All Models.
  3. Troy Bilt PartsSearsPartsDirect.com
HERE IS THE ACTUAL PART YOU CAN BUY FROM EBAY!!!!!!!!!!!!
http://cgi.ebay.com/Troy-Bilt-NEW-Bumper%2FGuard-Attachment--Part-%2311045_W0QQitemZ280344217654QQcmdZViewItemQQimsxZ20090511?IMSfp=TL0905111310008r5209
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Model Series 860
sounds like a bad tranny if this unit is under warentty DO NOT ATTEMPT REPAIR . if you attempt to repair this yourself you can void any warrenty
Sep 19, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
312 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
