Question about Whirlpool GS460 Gas Kitchen Range
Oven Not Working
The ignitor glows red, but the oven will not ignite. I smell gas when the oven is turned on for more than 10 minutes. The top burners work. It is a Whirlpool model # SF315PEMB1
    President:
  • 1,314 Answers
See if your broiler works if it does replace the bootom ignighter even though it glowes does not mean its working right it has to pull a ceartain amount of amps for the safty valve to open if the broiler doesnt light then the safty valve needs replacing and reply for futher info
Posted on Aug 17, 2008
SOURCE:
Ignitor glows but burner doen't ignite. Don't hear any gas flow or smell any gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 26, 2011 | Ovens
Oven has worked on and off for the last year, now doesent work at all, i have the igniter exposed and it is glowing red, you do not smell gas at first but after about 2-3 min you begin to smell the gas,...
If your unit has a separate gas valve for the oven burner, that would be my first guess. But I would also check to make sure that the thermocoupler was not corroded, coated or defective.
Jul 15, 2011 | Ovens
Our burners light but when you turn the oven on you can smell gas. Can you tell me what is wrong
most of these will have the oven bake ignitor become weak and not ignite the gas when turned on.
you should see the bake ignitor try to glow orange but the gas will not lit to the burner.
without a digital meter to read the current, should be 3.2-3.5 amps then you wont know if the ignitor is weak.
you could try to just replace it and see if that fixes you trouble.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove the burners are working but the oven is
Hi, The ignitor in the oven does not spark. It glows and has to pull enough amps to open the safety gas valve. The most common issue with these ovens is the ignitor. It can glow red but not be strong enough to open the valve. Remove the bottom panel in the oven and you can see the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Ovens
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Oven out/flat top has hot spot/burners ticking everywhere
heatman101
Jan 11, 2009 | Viking VGRC605-6 Gas Kitchen Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
GE RANGE MODEL #JGBP35BEA2BB
Sounds like that ignitor is weak.  When the ignitor glows it builds up resistance to the gas valve for gas to come in.  If it sometimes takes 10 min then the proper resistance isn't there and this will give you that gas smell.  Replace the ignitor and this should solve your problem.  Can expect to pay $80 - $100 for the part.
Oct 14, 2007 | Kitchen Ranges
Whirlpool GS460 Gas Kitchen Range Logo
266 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
