Question about Patton U2-1887HO Floor / Box Fan
I have a 3 speed fan with a red, blue, black an white wires, how are the supposed to be wired with power. the wires go to a little black box that appears to just be wires with no circuit board
    New Friend:
    New Friend:
Motor Wiring
Fan Speed Wire color Switch
High Black (1)
Medium Blue (2)
Low Red (3)
Motor White with Black stripe is Return connect to A.C. Neutral
COMMON - WHITE (L) AKA AC Hot
Sp3t Rotary Switch, off/on/on/on
CARLING TECHNOLOGIES Rotary Switch 700-BL
http://www.grainger.com/Grainger/CARLING-TECHNOLOGIES-Rotary-Switch-4X087
(2)
(3) ' -- ' (1)
(L) --
Posted on May 30, 2013
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
Posted on Jul 22, 2011
  • jdm2831 Sep 08, 2011
    Can not help, but I am looking for the same switch. If you find a source please post it.
    Thanks / John
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
Cant get the fan to go without the light being on
You have it wired wrong.
Power should leave single switch in a black hot wire and arrive at fan box on ceiling.
Your ceiling box will have at least 1 black Hot wire and 1 white Neutral
The fan will have 3 wires for connection purpose. Black, blue-or-red, and white.
Twist Black + blue-or-red together and connect to Black Hot wire from switch.
Connect fan white to white neutral.
Add a comment with more details.
Sep 19, 2012 | Dryers
I am installing a Mars 1/3 hp fan motor. It has a black wire,red wire, blue wire, yellow wire and (2) brown wire that go to a capacitor. May Furnace has Black power wire, red wire (speed) and white common....
Hello, Typically your common wire will be white, high speed- black, medium speed- yellow, medium low-blue, red- low. The motor could still run for a short time if it was wired wrong but will either trip a breaker or go off on it;s overload when it's gets hot.
Feb 26, 2011 | Heating & Cooling
Need to know how to wire this fan. Not using a remote or wall switch
Hello! W/D here.
In your ceiling box, you'll find 3 wires; black, white and bare copper.
In your fan, you'll see 4 wires; black (or red), white blue, and green.
With your breaker tripped, connect the green wire on the fan to the bare wire in the ceiling (this is your ground).
Connect the white fan wire to the white ceiling wire (this is your common).
Connect the blue and black (or red) together, and connect these to the black wire in the ceiling (this is the hot lead, and will supply power to the fan and the light).
Best regards, --W/D--
Feb 13, 2011 | Westinghouse 78500 Casanova White Ceiling...
Wiring heater, vent, light with 12/2 and 12/3 from switch to unit. email: lfranklin5@charter.net
I wish we had more information to go on here.
1) You have 2 cables to to the Heat-Vent-Light
One cable is 12-3 and 1 cable is 12-3
2) That's where it's gets fuzzy.
What color wires are on HentVentLight?
Is power at the ceiling box or at the wall box?
What other wires are inside the wall box?
What kind of switch are you installing?
3) With that number of wires, it sounds like power is at ceiling box.
Power would arrive at ceiling box on one cable that has a Hot-black and Neutral-white wire.
4) Start at wall box:
Let's suppose you are installing a wall device that has 3 individual switches, with one switch for each HentVentLight.
The Hot wire from ceiling box would drop down into wall box on a black wire, and this wire connects to brass screw on switch.
Wire going to heater connects to one of the silver screws.
Wire to fan to another silver screw
Wire to light to another silver screw.
5) Work at ceiling box:
Let's suppose your HentVentLight has 4 wires: Black for light, Red for fan, Blue for heater, and White Neutral.
The white neutral connects to Neutral wire as described in #3.
Black, Red and Blue connect to each of the wires that come up from switch.
Add a comment for more free help, and fill in the missing information.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 01, 2011 | Broan-NuTone FAN CONTROL SWITCH
Installing fan & light control (27182) - in the box, there are red, white and black wires. On the control, there are red, blue and black. So, black to black; red to red; right?....does blue go to...
Under normal circumstances, NO! Black is normally power in to a box and to a switch. The switch controls the power out to the red line and most likely the blue line. White is always circuit neutral (ground). Your power will most likely come in via black and then go to the lights on either red or blue and to the fan on the other wire, either red or blue, the color you did NOT use for the lights. Some place you should also have a bare or green wire that would act as equipment ground, connecting to the metal of the box.
Sep 06, 2010 | Hunter Ceiling Fan Light Switch Control
Wht is the correct wiring (red, white, blue, black) for the three speed switch?
White is the common or neutral...
Black is the high speed...
blue is medium...
red is low speed...
hook them up right in that order....
heatman101
Aug 17, 2010 | Lakewood HV 18-c Floor / Box Fan
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in...
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
Oct 03, 2009 | Hunter 52" Ceiling Fan With Light And...
Wiring a Hampton Bay ceiling fan
Hi Rexter,
I would pull the cover off of the Light switch and look at the color of the wire leaving the Variable speed device. I only assume the red wire is from that. I do not like to assume anything. So you must verify that a red wire leaves the Variable speed device. If it does, then i am assuming you dim the lights with this Variable device. The fan has its own built in Variable speed setup. In the case that the red wire belongs to the variable device, wire the Red to Blue(light), and Black to Black Whites to white. Green to Ground. bare wires to ground.
Nov 30, 2007 | Hampton Bay 24002 Ceiling Fan
Patton U2-1887HO Floor / Box Fan Logo
1,622 people viewed this question
Top Patton Dryers Experts
Mohamed Ismail
Mohamed Ismail
Are you a Patton Dryer Expert? Answer questions, earn points and help others
