Question about Engel Freezer 22 Qt. Fridge/Freezer
Fitting a Zanussi fridge thermostat
Hi all,
I have purchased a new thermostat for the fridge on a Zanussi ZFK-67/43 RF. I have traced the old tube/wire around the back of the fridge and then it goes through a hole into the back of the fridge. I have tried to pull the tube/ wire out but I presume it must be fixed inside? Looking inside the fridge there is a back panel and I assume the thermostat wire connects to the back of that. Can anybody please advise how to get the old wire out and the new wire in.
Many thanks
iwish
    President:
  • 1,462 Answers
The stat is clamped to the backplate of the frodge with a simple clamp held just by two screws. undo the clamp. the stat capiliary may be bent back on itself, if so straighten it and it will pull out
Posted on Oct 18, 2008
Zanussi fridge freezer wont stop making a whirring noise
Sounds like the unit is goosed and is trying none stop to get the temperature down in the fridge.
That is of course unless the ice is building up like an iceberg inside the cabinet in which case the thermostat has gone
Dec 06, 2009 | Freezers
Freezer seems to be working fine but fridge is not cold... fridge is on top of freezer, it is a frost free zanussi, not sure which model thou, just coming up to 5 yrs old ? any help would be great thanks
A fan controlled by a thermostat is required to move the cold air from the freezer to the refrigerator for cooling. Use a volt meter testing the voltage on the fan. If you have voltage it is a bad fan. If you do not get a voltage test the thermostat. If it measures zero ohms short the thermal switch or if it is a short open one lead. If the fan works replace the thermal switch.
Sep 01, 2009 | Blueair Freezers
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Zanussi ZX 57/3 fridge and freezer not working
Hi . Most freezers with the condenser coils at the back do not work when the temperature where it is placed gets below (( 5 degree c ))?? IE in a garage if it is freezing weather outside. One solution is somehow to keep the condenser compartment warm. Check the makers website. for what they say about it
Jan 10, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer very hot at the back
It is usual for the back of a fridge or freezer unit to get hot at the back as it uses a thermal transfer or heat pump process. As a freezer tends to cool the inside much more than a fridge it will obviously get hotter.
Make sure there is sufficient air flow around the rear of the unit and that no one can touch the rear radiator element, (to prevent burns.)
More expensive freezers actually use a fan to help circulate air around this rear element.
See http://uk.danfossuniverse.com/page2072.aspx for a more graphical demonstration of the workings.
Dec 24, 2008 | Zanussi 1.77 cu. ft. / 50 liter Upright...
Auto defrost is not working on my zanussi ice free fridge /freezer
You have a defrost problem. It means you have 3 parts that can be involve ( timer, defrost thermostat, element) most of the time it's the timer. Hope it was helpful. :)
Francois
Aug 25, 2008 | Freezers
I have an unexplained smelly zanussi fridge/freezer model Model zx99/5si? I have a zanussi frost free fridge/freezer model Model zx99/5si which is just 4 years old and it is now giving off a revolting...
Hi - we had this problem, and it was in fact where some blood from a defrosting pice of meat drained into the compressor condensation tank and began to decay!
I agree the smell is terrible, so a good clean up is needed but this solves the problem immediately!
Kind regards,
Mike
Aug 14, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Zanussi refrigerator
make sure that the fridge temp control is not set too hi also check that the drain away at the back of the fridge is clear.
Thanks J
Jan 05, 2008 | Freezers
Fridge not cooling
Three most common problems are bad evaporator fan motor, defrost problem, or damper motor.
Sep 30, 2007 | Freezers
Engel Freezer 22 Qt. Fridge/Freezer Logo
602 people viewed this question
Top Engel Freezers Experts
John Tripp
John Tripp
Starnley Johnwells
Starnley Johnwells
Victor Nwachukwu
Victor Nwachukwu
Are you an Engel Freezer Expert? Answer questions, earn points and help others
