Question about Honda Electrical Supplies
Is there any reason that the idle down solenoid on a Honda Blackmax generator shouldn't be hooked up and if not what is the procedure?
4 Suggested Answers
protek480
  • 1714 Answers
SOURCE: I have a Honda generator model EM3500X with auto
The control board that senses load (current) is not working.It should drop to low with no output current. (nothing running)
Posted on Jul 07, 2009
  • 12650 Answers
SOURCE: should I cover my generator while it is running
no possible to over- heat unit the engine needs air to stay cool also the covering can catch fire if u want to protect while out running in elements a make shift tent style cover open on bottom pitched type over top, mine is left out all year my daughters are grown so i use their old little tykes building it fits inside has enough room for air and the building protects it from the elements as well as hiding its appearance
Posted on Feb 25, 2010
  • 3 Answers
SOURCE: plug wiring diagram for 240v outlet 7000w blackmax
Probably its similar to the wiring on page 31 of this manual (pdf page 28) of this manual, reference NGK-7000HE: http://www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Honda%20engine.pdf
Posted on Mar 14, 2010
Having trouble getting my BlackMax 7000 watt trifuel generator started on Propane.
Clean off the fuel connect points. Probably just not a clean line from sitting so long since last use.
Dec 25, 2014 | Honda Black Max 7000 / 8750 Watt Portable...
Have continually to increase speed to maintain voltage
Check the idle-stop screw. They tend to back out, causing the generator to slow down and not maintain regulation
Oct 17, 2014 | Honda Ex5500 Generator Solenoid Stay...
Honda eb5000 generator
I have a EB-5000 model B 50 Honda generator the high idle works but can't get it to idle down, I change the switch because it was broke, I looked all springs are there, when I put my finger on the governor rod and pull it back idles down, any suggestions
Apr 16, 2013 | Honda Eb5000 Eb7000 5000 7000 Generator...
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
Mar 04, 2013 | BlackMax 3000 Watt Gas Generator - Powered...
How to Adjust idle RPM for a 2003 honda accord. some people were talking about a screw on the throttle body. but I can't find that screw. How do you go with adjusting this and where to find it ?
First, you shouldn't adjust the idle. If the idle isn't correct, that means there is an issue somewhere - not that the idle needs to be adjusted.
There isn't an adjustment screw. To adjust the idle, you will need to move the TPS (Throttle Position Sensor) forwards or backward. To do this, you will need to remove the tamper proof bolt and replace it with one that can be loosened and tightened.
Mar 04, 2012 | 2003 Honda Accord
When the egr valve is bad on a 1992 honda accord wagon what happens?
If it's stuck closed, you will feel no ill effects. If it's stuck open, the car will not idle right and be hard to start. If you're getting an egr trouble code from your accord, test the egr valve to make sure it's working; use your finger to push up on the egr valve diaphragm, while the car is idling....car should shake and shut off if the egr valve is good. The one vacuum solenoid that feeds the egr valve, on that generation accord, is known to go bad and cause the egr trouble code. Check that solenoid if the egr valve tests ok.
Sep 15, 2011 | 1992 Honda Accord
Plug wiring diagram for 240v outlet 7000w blackmax
Dec 25, 2009 | Electrical Supplies
Where can I find an owners manual for a Black Max 8125/ Honda GX390 OHV generator? I searched Honda's site but not there, no black max site. My lawn guy pulled a wire off and I need to see where it is...
low oil sensor will not cause the motor not starting.
most likely is th ground wire.
you can try to attach that wire to any surface and try to start it. of it start, then you have to dis-assemble the head and find out where the wire should be attached.
if not, the wire is attached to a hot side. either way you have to dis-assemble the head.
http://www.honda-engines.com/engines_owners_manuals/ownersmanuals/gx390.htm
here is the site for the manual.
Apr 07, 2009 | Electrical Supplies
Auto idle on a reddy rgh11000 ie will not idle down
This sounds like the idle control solenoid has become misadjusted. To check that this is the case, locate the throttle lever and follow it back towards the governor arm until you find the solenoid. Start the generator and switch on the idle control while watching the governor arm where it passes near the solenoid, if the arm snaps back and forth you probably have a bad adjustment. To readjust the solenoid loosen the jam nut on the core of the solenoid just enough that you can turn the core by the square bit on the end. Adjust the core 1/4 turn or so at a time until the governor arm stays in position when the idle control is on, then turn idle control off and make sure that the governor arm goes back to the full throttle position. You may have to fiddle with the adjustment a little until you find the right spot. Tighten the jam nut back down and you're good to go.
Carl
Dec 09, 2008 | Honda 6370C - Parallel Power Kit For ...
Electrical Supplies Logo
119 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
