Question about Craftsman Garden
I have a Craftsman 917.272950 model #. The mower driver belt slipped off and I can't figure out how to put it back on. I have the manual and can't tell by the photo what on earth they are talking about. My husband is disabled so I'm trying to fix it. Please explain in detail how this stupid belt goes on!? Thank you.
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
I need to replace the drive belt on my lawn tractor.
Things You'll Need
  • Wrench set
Show MoreInstructions
    • 1Find out the driver belt's part number. This can be found in your lawn mower's owner manual.
    • 2Find a store that sells Craftsman lawnmower parts and see if it has your specific belt in stock.
    • Sponsored Links
    • 3Clean out the underside of your mower's deck, making sure there are no leftover pieces from your old belt still stuck inside.
    • 4Find your mower's tensioner, which keeps the pulleys in place, and loosen it (this usually involves loosening a single bolt). Then slide the pulleys closer together so that you can fit the belt over them more easily.
    • 5Arrange the driver belt over the pulleys (you should refer to your user manual for the exact configuration of the belt over the pulleys, since this will vary depending on the specific model of your lawn mower).
    • 6Tighten the tensioner back up, leaving only about a finger's width left of play in the belt.
Sponsored Links
Read more: How to Replace a Craftsman Lawn Mower Drive Belt ' eHow.com http://www.ehow.com/how_4826688_craftsman-lawn-mower-drive-belt.html#ixzz27K3g01yM
Sep 23, 2012 | Garden
How to change drive belt on craftsman ltx1000 18hp kohler
Find out the driver belt's partnumber. If you don't have the manual call Sears and tell them the model numberor look it up online. Clean out theunderside of your mower's deck, making sure there are no leftover pieces fromyour old belt still stuck inside. Findyour mower's tensioner, which keeps the pulleys in place, and loosen it (thisusually involves loosening a single bolt). Then slide the pulleys closertogether so that you can fit the belt over them more easily. Arrange the driver belt over the pulleys (youshould refer to your user manual for the exact configuration of the belt overthe pulleys, since this will vary depending on the specific model of your lawnmower) Tighten the tensioner back up,leaving only about a finger's width left of play in the belt.
Jul 03, 2012 | Garden
My craftsman 22" self propelled
Your problem is at other end . Engagement problem is probably due to a loose belt. Make adjustment in that area of mower. GOOD LUCK.
Jun 16, 2011 | Craftsman Garden
I posted the below problem last night with the request for additional information reply sent 2 hours ago. I need to use this mower today. I need to have an answer. THanks Problem with the...
Thought I posted a solution earlier on this, but it was my first post and I don't see it here so I'll try again.
Google search on your model shows the drive belt diagram on page 27 of the manual.
link below:
http://www.mytractorforum.com/images/reference/dgs6500.pdf
Looks like mine.
basically need to remove front pulley by loosening center bottom bolt while holding the center nut on top of motor.
Slip belt over the rear pulley first and then straight toward the front, slip belt on front pulley and then slide pulley back onto shaft.
Then wind through the rest of the pulleys etc..as seen in the diagram.
Jun 08, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Can't figure out how to put my belt back on my garden tractor, deck blade belt, craftsman model 917255950
Go to www.searspartsdirect.com. Put in your model number and it will come up with an IPL and diagrams for your mower.
Jun 25, 2010 | Garden
Garden Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
