Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Freeze and ice maker quit making ice and prevent it to keep food frozen
    Problem Solver:
  • 15 Answers
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacuum cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air out the bottom.The fridge
Posted on Jun 01, 2011
Continuous knocking noise from ice maker. Ice maker has been off for past 3 months. Only thing that will make it stop is turning it off or unplugging it.
Hi Marcel,
Thank you for contacting fixya.
Our ice maker recently had its water inlet freeze up, preventing water from filling the trays. The mechanism kept dutifully trying to push nonexistent ice cubes into a bin that never filled up, which might account for the knocking noise in your case.
To defrost it we just unplugged the unit, took all the food out of the freezer section, and left the door open for a couple of hours. It wasn't long enough for any of the frozen food to defrost, and since we were careful to minimize opening the refrigerator section's door, the food in that part stayed cold enough to be safe as well.
Feb 09, 2014 | Frigidaire FPHB2899LF
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Why does my ice cube maker quit working and temperature in freezer is the same as fridge.
ice maker will not work if freezer is too warm . it must be 15 deg or lower and if fresh food is that cold then the food is frozen. the freezer needs to be 0 to 5 deg and the fresh food side 38 def is best . / you may be having a defrost problem and the cold coil is packed with ice and prevent ing air flow .. ck for ice in back of freezer .. mm
Oct 22, 2010 | Amana Refrigerators
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer will not keep foods frozen fridge will not keeep temp.
Sounds like a main control board problem keeping the freezer fan from working . If no air flow to the top of the freezer , the icemaker will stop working and the ice will begin to melt ( leaking from freezer ) . The coils will start to freeze up due to no air flow across them . If continued for a period of time , the cold air could return thru the return vent located in the bottom of the ref/freezer section and freeze the water tank in the refrig section , causing the no water thru dispensor .
Jul 11, 2009 | Hotpoint HSS25GFP Side by Side...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
My freezer is not keeping food frozen
defrost system is malfunctioning causing build up of ice. remove back panel of freezer, check for ice build up. if so, defrost carefulle with a hairdryer. also check drain is not blocked by ice. if it is, use hot water to get rid of it. (takes time)
Apr 25, 2007 | GE GSH25KGR Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
119 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
