Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso The washer gets to about 13 minutes left and then the display reads ob and stops.
  • mllong1963 Aug 22, 2008
    since this posting I have taken it apart and put it togther again the erorr codes now it gets to the rinse section it pours out the side of the washer drum from the overflow valve.
This could be an out of balance condition. When its happened to my washer, I rearrange the load if its large enough, and if its not, I find other items of like weight and add them to the load and start over. Calypso's are sensitive to fabric weight, so If you're washing towels, wash only towels and wash cloths. Make sure you put small items, like bras, panties, nighties, etc., in mesh bags and combine them with other light weight fabrics.
Posted on Aug 22, 2008
  • Shirley3065 Aug 22, 2008
    Holy moly! Call the repair person. Water gushing out is a bad thing. If you don't know a good one, call Whirlpool for a listing for your area. It will be about $65 for the service call plus time and materials unless its under extended warranty. Good luck.
What does a code o6 mean on a Whirlpool Calypso top load washing machine.
is this the code your refering to
ob" Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for Off Balance
The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
Press STOP/CANCEL to clear the display
cuz they list no code 06 hope this helps
Jul 18, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have an error message that reads ob. I have an
OB MEANS OFF BALANCE if the motor controller detects an unrecoverable off-blance condition, the machine controller will shut down and display ob. the lid switch must be opened at least once before restarting the cycle if this condition occurs. opening the lid will allow you to view and redistribute the load. press stop/cancel to clear the display. hope this helps.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Heelo, during the spin cycle the washer stops and
Water not draining from the tub. Check for hose crimp ir clog. Here is your manual codes on page 19.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/8566930.pdf
Aug 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer machine
Off Balance. From the service manual (you can google error codes for these machines), if the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for off balance. The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow you to view and redistribute the load. Press STOP/CANCEL to clear the display.
Feb 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LD and OB on Calypso
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating
OB:
will shut down and display an “ob” for off balance.
Basically, it sounds like your drain pump is bad or clogged, and the extra water is throwing the spin cycle off balance
-Perry
800-Appliance San Diego
Dec 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso ''ob'' problem
ob Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
if this does not fix the issue it is most likely the strut and shock system that is falty on the machine. you could replace them yourself but they are fairly expensive
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Timer won't count down
service bulletin says the washer times can do that as the washer senses variables changing and all times are estimations and its normal .if the washer detects failure it will set a trouble code hope that helps
Dec 30, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal De
