Question about Moulinex DG6 Food Processor
I have a Type RL1A.A Super Chef. Has worked beautifully and faithfully for 30 years. Last monthe the grinder knife blade broke in two. How do I replace it?
HOW CAN I TELL WHICH PART OF THE PROCESSOR NEEDS REPLACING WHEN IT WON'T CONNECT
Difficult to tell as I could be a few things.
Motor
Safety interlock
On Off switch
Check the safety pin or whatever stops the power unless the bowl and lid are fully in place. With the blade and bowl off you can defeat the safety by inserting a pen into the hole if it has one or a teaspoon handle into the slot if it has one.
I am a chef and in a commercial kitchen, home type processors last 15 months to 2 years max.
Even if you find the problem your problem will be finding spares unless it is a top brand.
Jan 27, 2016 | Food Processors
Varco Super Chef TYPE RL1A.A (Made in France in the 60's grinder and shredder) had a blade in the shape of a cross (X) , a new blade is needed for my machine, Thanks
I have a super chef grinder type RL1A.A and i have lost the cutting disc that is shaped like an X. Are these parts still available for purchase anywhere?
Sep 26, 2010 | Food Processors
I have a Super Chef Type RLIAA Varco Inc Made in France Brevete SGDG.Could you please point out a site were I can obtain parts
I have a Super Chef grinder type RL1 A.A. I lost the cutting disk cut like an X . tell where i could find it.
Dec 12, 2009 | Moulinex DG6 Food Processor
Model EP90
I have the same problem. I called bravetti/europro and they told me that they don't support this model any more and don't have replacement parts either. What I do to use it is I use a knife as the blade on the lid and stick it in the slot and move the switch toward the back. This is eaiser when the blender is off of the unit. You can do the same thing to use the blender but switch is a little harder to push.
Nov 03, 2008 | Bravetti Platinum Pro Quad-Blade Food...
Oster regency kitchen center meat grinder attachment
What exactly are you having problems? Setting up the grinder? The hopper inserts into the back side of the mixer head locks in place with a set screw. Then insert the piece that looks like an auger push it all the way back. next, comes the four blade knife it looks like this " + " if look at the center of the blade you will notice a square hole on one side place that side towards the auger. Then there are your grinder attatchments I only have two,one coarse, one fine. place one of them against the blades placing the tabs in the cutouts on the discharge end. mext there is a large metal cap thread this on the discharge. Set the control to grind and the speed to 10. You are set to go. cut the meat into strips or chunks that will fit down the infeed and use the plastic plunger to push them into the auger.
Oct 26, 2008 | Food Processors
Rival 2250 food grinder ( cutting blade)
If you still need the cutting blade for rival grinder model 2250, I have one. email me if interested. 12gaug@comcast.net
Jul 15, 2008 | Rival 2275WP Food Processor
Food grinder
ring collar is broke on rival food grinder
May 12, 2008 | Rival 2275WP Food Processor
Moulinex DG6 Food Processor Logo
110 people viewed this question
Top Moulinex Food Processors Experts
Colin Stickland
Colin Stickland
Ross Keen
Are you a Moulinex Food Processor Expert? Answer questions, earn points and help others
