Question about Janome Sewing Machines
My Heart Truth 2008 sewing machine was sewing fine when the top thread got caught between the bobbin case and the machine - and it has been producing nothing but knots ever since. I cleaned the lint out of the bobbin case area and changed the needle - what do I try next?
  • 1 more comment
  • tmagsig86 May 29, 2011
    The answer I received was generic thread tension problems. My thread is getting caught in the bottom of the machine. It wraps around the bobbin case, but doesn't make it all the way around. Then without completing the first stitch, it wraps the next stitch around the bobbin case - and gets stuck again (and again and again). it was working fine with the tension settings as they are, with the same thread and fabric one day - and just producing knots the next.
  • tmagsig86 May 30, 2011
    Thank you for not giving me a "canned" answer!
    I did know bobbins are different - and I "hid" my singer bobbins when I bought the janome. I'm sure I have the right one in the machine. I did not know they could go bad!
    I also knew all thread isn't equal. I never buy the 100% polyester thread - and can get rather picky about it. My time is worth more than the pennies the cheap stuff saves. Could a spool of thread "go bad" in the middle??
    I was expecting something like "make sure this screw is tight" or "drop some oil here". I hope these easier suggestions help - I will test them tonight!
    Thanks!
  • tmagsig86 May 31, 2011
    Well, I changed the bobbin and put in different thread in the top. Played with a couple different stitches - a couple tried to knot - and just kept the machine going until it was consistent. THEN I put the "old" bobbin back in - and it worked! THEN I put the same "old" spool of thread in - and it worked! So - I still don't know for sure what the problem was - but I'm happy again!! Thank you for your help - and the education about bobbins!
  • 3,018 Answers
  • Assuming you threaded your needle right I would start with looking at your bobbin. They do go bad and you could have that thread to tought around the bobbin. If you have a spare bobbin then string a fresh bobbin, and pull the old one out and replace with the new bobbin.
  • Also note that cheap thread will mess with a sewing machine something awefull. Had this Walmart thread one time that just tore and knotted. New quality thread took care of that.
  • Also bobbins are not a one size fits all. Make sure to use the same style bobbin every time. Again, as with thread, cheap bobbins are not always netter.
Regards, Tony
Posted on May 29, 2011
  • 2 more comments
  • Iron
    Iron May 30, 2011
    • Sure, thread can go bad just from storage. Thread is spooled, naturally, and can get become tangled or over taught further inside the spool from undo stress. Let me know how it works out for you.
    Regards,
    Tony
  • Iron
    Iron May 30, 2011
    As for how bobbins go bad, they spin constantly but are not on bearings like a car wheel. So the inside of the bobbin that sits on the shaft begins to open up and warp and gap. When a bobbin does this it does not feed the needle properly, because its not seated properly, and you get faulty sewing. Often times you can't see with the bare eye this has happened. Trial and error is the only way. And bobbins come in wood and metal and different sizes. The wrong one, even the right one but cheap, will or may not work.
  • Iron
    Iron May 31, 2011
    • Wow, that is odd. I too am happy you got it working. Happy sewing to you!
    Regards,
    Tony
  • Iron
    Iron May 31, 2011
    And your welcome :)
    Tony
  • 1,238 Answers
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.Don't forget to rate my answer
How do I adjust tension on a Necchi Lydia 510 sewing machine?
loops under fabric means top tension needs to be tightened
try cleaning the top tension dial with some unwaxed dental floss and see if that helps. if it doesn't then the tension dial may need to be replaced
also check to make sure the spool of thread is not getting caught on the spool holder
also try a new needle--one that is correct for the fabric being sewed
Feb 10, 2015 | Necchi Sewing Machines
I have a hyundai 8 stitch sewign machine been working brillant but last night it kept missing the tread and the thread breaking or jabbing . today looking at it i see when it jabs the Bobbin Case Inner...
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
if the sewing machine has a top loading bobbin, you may have to have the sewing machine checked to see if there is something wrong with the bobbin case or the hook and hook race.
I suggest try a new needle--one for the fabric being sewed
also try another bobbin
rethread the sewing machine top and bobbin, using every thread guide.
Aug 21, 2013 | Sewing Machines
I have a LS1217 ..it was working fine then I had to refill the bobbin...that went normally but when I tried to see again e the needle thread is getting caught up and not picking up the bobbin thread. I...
have you tried a new needle
try turning the bobbin the opposite direction in the bobbin case
make sure the top thread has not come off the thread take up lever
Mar 20, 2013 | Brother LS-1217 Mechanical Sewing Machine
How do i use jean thread on my juki industrial sewing machine
are you using a denim needle for sewing jeans?
where is the thread getting caught up at?
make sure the bobbin is turned the right direction in the bobbin case
Feb 13, 2013 | Juki Sewing Machines
Toyota 9400 Sewing Machine top thread caught between bobbin casing and spring causing jam
it would be a very good idea to have the machine serviced since
someone gave the machine to you, and having the bobbin
case replaced would be a good idea and having the spring
checked would be good too.
Feb 11, 2013 | Toyota Sewing Machines
Singer bobbin thread not being caught
try rethreading the machine top & bobbin
change the needle--flat side to the back of the machine, make sure the needle is the right one for the fabric being sewed
clean under the needle plate & in the bobbin area for lint or theads
May 10, 2012 | Singer 3323S Sewing Machine
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
I have a brother pe 770 and the bobbin will not catch the thread. The thread will wrapped and tangled up around the bobbin case and bobbin, but will not catch the bobbin at all. I chcked the needle, it is...
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Dec 14, 2010 | Brother PE770 Computerized Sewing Machine
The upper thread keeps getting caught under the bobbin casing when sewing. The machine will stich, but when I pull it out there 3 threads pulling out instead of the 2 there should be. I have read the...
Other than your machine being out of time and needing service, following are suggestions to try:
Be sure to use the correct type of needle for the thread and fabric you are sewing, ie sharp, top-stitch, embroidery, universal, or microtex for woven fabrics and ball-point needle for fine knits.
AVOID old or bargain bin thread.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Check that the bobbin is turning the correct direction in the bobbin case and the bobbin case is properly threaded.
Set the top tension to the midway point.
Re-test your machine and tweak the top tension so the top and bobbin threads meet in the middle of the fabric.
If the thread continues to hang up, take your machine for service and adjustment.
Jul 27, 2017 | Brother CS-6000
Thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Nov 12, 2007 | Sewing Machines
Sewing Machines Logo
217 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
