Question about Whirlpool ACQ158XP Wall/Window Air Conditioner
ACQ 158 XP
Fan stopped running. It will move only on turbo and stops after 15 minutes. Compressor fine. Seems like it needs oil. I took the front off but i am puzzled on how to oil and pull the insides out without taking the whole thing out of the window.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Unfortunatley the only way to get to the inards is to take the unit out of the window. My fan stopped working also but I found a replacement here
http://www.partstore.com/Model/Whirlpool/Whirlpool/ACQ158XP0.aspx?ModelAliasNumber=acq158xp
good luck
Posted on Aug 26, 2008
Compressor stops running.
in dehumidifier modes work like in cool mode..try in cool mode too see if it work
Nov 30, 2013 | Haier CPN14XC9 Air Conditioner
I moved my refrigerator to vacum (Frigidaire model PLHT217TAK 2002) and since then the warm air stopped coming out from the front bottom vent. It also stopped making noise, it seems to want to start but...
the condenser fan motor is what blows the air around down there,pull out the machine remove the back bottom panel and you'll see the fan,check it to see if something is stuck in the fan blade keeping it from spinning,do this right away,if the fan isn't blowing you can cook your compressor,if something is wrong with the fan motor you can leave the bottom panel off and stick a regular fan back there to keep the compressor cool until you fix the fan motor.hope this helps
Jun 23, 2011 | Frigidaire Refrigerators
Fridge sounds like my air compressor in the garage when it runs. Will run for about 25 minutes making this noise then stop for about 15 minutes. Suspect the compressor is going or low on coolant.
It may be the compressor but I suspect that it is the fan making the noise...
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Feb 11, 2011 | KitchenAid Refrigerators
Weird problem, 2005 Kia Spectra5, after air conditioning or defrost is running for about 15-20 mins, seems like the air stops blowing, even though the fan is running, turn the heat settings to fan for...
you may want to check and see if the cycling switch is defective...it engages and disengages the clutch on the compressor ..i would check and see if the clutch stops engaging when the a/c starts blowing warm
Feb 08, 2011 | Air Conditioning and Heat for Kia Spectra5
Samsung Ac compressor stops after 20 minutes and fan keep running. Again after 10-15 minutes if ac is restarted the cooling happens for 20 minutes and compressor stops.
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Mar 15, 2009 | Samsung AW0693L Air Conditioner
Coleman mach 8333 kicks breaker
I changed out the startup and run capacitors. A/C runs fine now
Jul 22, 2008 | Coleman Mach 15 Air Conditioner
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
DH30 Dehumidifier Compressor Does not Operate
I just picked one up at a tag sale, seller said it worked sometimes. Seems to have the same problem as yours. I took the time to tweak all of the connections and then re-soldered the control board with no luck. I finally disconnected the humidity control and it worked fine. By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off. Conclusion so far is that the humidity control rheostat is bad.
Note: Now while running the fan runs continuously and the compressor cycles on and off every 10 to 15 minutes. This may to be normal since the unit appears to be doing its job and I'm not sure how it is supposed to run since a purchased it broken.
Aug 05, 2007 | LG DH30 GoldStar Dehumidifier
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
206 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
