Question about Sport & Outdoor - Others
Honeywell 2000i oil change method & specs I have the generator but no manuals
3 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Just purchased a Honeywell generator
Hi d gautreau...
Contact Honeywell at this link below and fill in the form to request a free user manual for the Honeywell 2000i Inverter Generator:
https://eaccess-checkout.com/contact/honeywell.asp
Address
HoneywellStore.com
407 N. Quentin Road
Palatine, Illinois 60067-4832
USA
Phone Numbers
Main Number: 847-701-3038
Facsimile: (847) 991-7189
Email Addresses
Sales: sales@HoneywellStore.com
Please take time to rate me
Posted on Aug 19, 2011
  • 7 Answers
SOURCE: Need a manual for honeywell generator model 6054 lpg
Can you please identify the problem you have with the 6054 generator. I may be able to assist.
Posted on Nov 23, 2011
How do I replace the pull cord on a Honeywell 2000i generator
Hello John,
The following video shows how to take these models apart.
The one he is doing is the 1000i but it is very similar to your 2000i generator! It should help you immensely in the disassembly of the unit in question
The recoil assembly can be purchased for about roughly $26.00.You could also replace the cord itself for a whole lot less than that if you have the know how!
Good Luck!
Rich Lilja
Dec 11, 2017 | Electrical Supplies
Why does my Honda 2000i Generator run but produce no power?
Check to see if there is a breaker that has popped as a first diagnostic step
Oct 12, 2014 | camperpartsworld.com Honda Generator EU...
Start run 2 min cut off then wont fire 30 hrs
check the coil.( dis pack) when they fail or start failing the spark at the plug goes orange should be a nice blue spark.
Jan 22, 2014 | Honeywell hw2000i 2000i
My EU 2000I ran my half ton AC unit for over a year. It now all of a sudden starts popping the 20 amp breaker anytime I turn it on. It only pulls 10 amps at startup. What's with this? Is it time to...
Make sure it isn't trying to start the HVAC with a locked compressor (IE it just turned off and is now trying to cycle on again) If it is shutting down due to low freq there is too much load for the HP the engine can deliver. That will cause too much current to flow and trip the breaker. Also be aware it takes 6 times current to start HVAC than to run it. How old is the generator? it may have normal engine wear and can no longer generate HP, Also when was it tunes up
Sep 30, 2013 | Honda EU2000i/Companion Parallel Cable/RV...
The starter Pull Cord on my portable generator will not pull easily or smoothly. I can get it to start but every other try the cord will not budge. I think I overfilled with oil on my last oil change. ...
Czorbach... Sadly it is said
"it is more harmful to RUN with too much oil
than none at all"
That is like saying each one might have a value...
Neither does.
Yes it is HIGHLY LIKELY
the engine COULD have been seriously damaged.
The simple truth is that oil... DOES NOT COMPRESS.
The crank-case is a closed area... HOWEVER
I'm guessing the case has a dipstick, fill plug and
several weaker spots that should clearly
fail before serious damage was done to
YOUR METALIC internals...
Perhaps you are just having an ugly coincidence
and your starter pulley was merely ... bent/damaged
during your PREVIOUS MEELEE...
I CAN NOT actually imagine you were REALLY able
to RUN your engine... ALL STUFFED UP like a
HYDRAULIC JACK.
Honeywell HW1000i Portable Inverter Generator Owner Manual
https://en.wikipedia.org/wiki/Carnac_the_Magnificent%E2%80%8B
May 13, 2017 | Honeywell 900W (1000W Max) Inverter...
How to make and connect remote kill switch for honda 2000i
If you just want to kill the engine.... run 2 wires to the remote switch. One wire will connect to the low oil level sensor wire (if oil level sensor has 2 wires only one will work../ trial and error) ) and the other to any grounding point on the engine. All you will be doing is grounding the ignition and shutting the unit down. You will not be shutting off output power before shutting it down.
Kelly
Aug 26, 2011 | Electrical Supplies
Just purchased a Honeywell generator 2000i and lost the manual. How can I download one.
Hi d gautreau...
Address
HoneywellStore.com
407 N. Quentin Road
USA
Phone Numbers
Email Addresses
Aug 19, 2011 | Computers & Internet
I have just got a second hand Quadpower Gen 2600 generator no manual, what oil does it take and where can I get a manual!!
go on line and type in the generators name and the manufacturers site will be there. they should be able to give you the specs and mail or email you a manual. usually there is oil designed for generators since they run at such high rpms for so long and it is found at parts stores and anywhere they sell generators but check with your manufacurer first in case they use something different in your unit.
Jun 04, 2010 | General Electrical Supplies
Sander failure when using honda generator
If you are using a 220 volt 4 hp floor sander, which is 95% of all floor sanders. you CANNOT use a generator less than a 25KV, which is about the size of a van. All Floor sanders draw over 80 amps at start up and during floor sanding all sanders run around 25 amps. If your motor is a Capactor style motor you can do detrimental damage to the motor. Many of my customers have done it in the past.
Dec 24, 2008 | National Tools & Hardware - Others
Sport & Outdoor - Others Logo
198 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
