Question about Whirlpool GEW9250 Electric Dryer
Dryer runs but no heat. model gew9250pwo serial number mr5158016
  • 2920 Answers
SOURCE: My dryer will run but won't heat
you either need a new heating element or limit switches
Posted on Nov 02, 2008
reg501
  • 413 Answers
SOURCE: Dryer runs fine, does not heat?
Remove the back and on the right side is the heater assembly. Attached to this assembly is a safety thermal fuse at the top and a heat limiter thermostat at the bottom. The fuse, thermostat or heater may have failed. The MOST common reason for any of these parts to fail is a clogged or restricted exhaust. Be sure to clean/inspect the exhaust system or the dryer will fail again.
Posted on Dec 25, 2008
  • 66 Answers
SOURCE: we lost the wiring diagram for the dryer and
From what I can tell you should be only dealing with two wires. The element should be slid, coils up, into the metal sleeve in the bottom right and the wires should connect to the prongs. If your wires arent reaching then you may need to splice some more wire in or replace the wire with a longer one.
Posted on Dec 13, 2009
  • 949 Answers
SOURCE: the dryer works but there is no heat
If the breakers are okay and you have power to the dryer the problem would be one of two issues.
The first and most likely is the thermal cut off. This is a small temperature activated fuse that will trip if the air flow through the heater is poor, this is usually due to a plugged lint filter or restricted vent pipe between the dryer and outside.
The second is the heat element itself has gone bad. You can measure it with an ohmmeter or physically inspect it for breaks. The image I have attached shows both. The T cut off is part 47 and the element is part 14 both visible with the lower panel taken off. The lower panel has 2 screws visible while laying on the floor looking straight at the panel.
The part numbers for the components are 279973 (cut off kit) and 3387747 (heater)
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: My dryer is about 7
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 23, 2010
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 | Dryers
Dryer will not operate
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your dryer.
Apr 04, 2017 | Whirlpool GEW9250P Electric Dryer
The dryer works only when it when it wants.
what do you mean,does the motor run but no heat,also send the model number,open the door and look around the opening and you'll see a tag with the model and serial numbers,just send the model number and a little more detail,it will start with 110. and 8 more numbers
Feb 20, 2011 | Kenmore 73102 Gas Dryer
I have a whirlpool model number gew9250pwo when i push the start button there is a click, then nothing happens at all...i have cleaned it, changed the thermal fuse, and the circuit board...any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2010 | Whirlpool GEW9250 Electric Dryer
Control Panel in my whirlpool duet dryer model #GEW9250PWO will come on & the dryer will not work at all. Unplugged dryer and plugged back up still doesn't come on. The light within the drum is on when...
First check for 220 volts incoming power to the dryer at the terminal block on the rear of the dryer.
If you have 220 volts,check continuity on part number 59(thermal fuse) in the attached diagram. No continuity is a bad part.
cut and paste this link to your dryer diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139909&diagram_id=951915#d951915
Jul 14, 2010 | Whirlpool GEW9250 Electric Dryer
The dryer works but there is no heat
Apr 23, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer runs but wont heat
There are 2 possibilities for this problem.
1. The limit switch is out. The limit switch is located on the heating element on the back of the dryer. This is a small button type part. it will have 2 prongs on it for 2 wires that slide on for power.
2. The heating element is out. This will be on the back of the dryer and depending the model it should be a long metal piece that has metal elements inside of it to heat the dryer. or it could be a large round unit. these can be tested with an om meter.
The limit switch will be the cheapest to start with on replacing.
If you need further assistance please do not hesitate to ask. I will need the make, model, and the serial number of the unit to help you further. the model and serial number can be found by opening the dryer door and looking by the hings. there should be a sticker with this information on it.
Apr 13, 2010 | Kenmore 64852 Electric Dryer
Dryer was working fine then quit heating
go to www.repairclinic.com enter your model number and your parts will come up for you to see. And to see what they look like good luck
Jan 13, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer problem
What brand of dryer is it? Model number? The lack of heating could be a number of things. Be sure the vent tube isnt clogged or pinched. The other options are bad element, bad thermostat or bad thermofuse. Depending on what type it is would also depend on how to make the repair, how to get to the parts, etc. Get me a little more information and we'll get you heated up. Jim
Sep 08, 2007 | GE DBXR463GB Gas Dryer
Whirlpool GEW9250 Electric Dryer Logo
273 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
