Question about Garden
I have a cub cadet mower trimmer with a 6hp briggs & stratton motor and need to know how the top cover comes off to change the pull rope can you help me?
  • 659 Answers
Ushally 3 or 4 screws around the shroud make sure battery is disconnected first because its ushally one screw has the ground wire on it. pop it up and you should be good. make sure you get the right amount of tension on the new rope its a pain sometimes.
Good luck
Posted on May 28, 2011
How do I get a Operator's manual for a cub cadet SRS621 lwanmower
mtd cubcadet should have it the model numbers changed allot so you have to be sure and have the right one sorry good luck
Jul 09, 2014 | Briggs & Stratton Briggs Stratton...
Charging system
diod is bad on briggs motor or stater is bad
May 18, 2014 | Briggs & Stratton Garden
I have a cub cadet rzt zero turn lawn mower that I'm trying to get started need to know how to adjust the valves on the mower
Can't say with knowing what engine you have such as Kawasaki, Kohler or, Briggs and Stratton.
Apr 17, 2014 | Garden
Ordered new mtr to repl B & S 6hp rated mtr on Yazoo Mfg Commercial Mower. The mower is not at ths site, so I can't give you the mod of new mtr, but it was a 9hp rated mtr w/controls on opposite...
In Briggs & Stratton motors used in mowers or similar equipment the spark is generated by a magneto : a magnet situated on the flywheel passes in front of the ignition coil and generates the spark.
If the engine is backfiring then the flywheel is incorrectly positioned - take it our and rotate it for one bolt
Aug 08, 2011 | 1992 Honda Accord
Have to change pull cord but rivits holding down cover am i to drill these out if so stupid design.
If this is a Briggs and stratton then you have to take the engine cover off which is held on by 4 bolts and replace rope. unless you have a rivet gun to replace the rivets you drill out
May 15, 2011 | Cub Cadet Garden
Broken pullcord
before you rethread it you must spin housing counter clockwise till you feel tension (if you let it go you have to restart ) then tread it
May 09, 2010 | Cub Cadet Lawn Mower Idler Pulley Replaces...
I have a Snapper Briggs & Stratton lawn mower Model Series 126T00 and for some reason it will not start.I drained the gas tank ,put fresh gas in it. I did a caburetor kit and it still will not start....
How about the key way? Its the timing of the motor. Its under the pull rope and the wheel under the pull rope. Might be cut or broke in half.
Mar 21, 2010 | Garden
I have a cub cadet 1080 series rider. The motor
SOUNDS LIKE THE STARTER OR YOU MAY WANT TO CK THE VALVE SETINGS LET ME IF THIS HELPS
Nov 02, 2009 | Briggs & Stratton Garden
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
