Question about Saeco Vienna De Luxe Espresso Machine
Resevoir leaking on Saeco Trevi(like Vienna)
My resevoir doesn't seat properly and leaks all over counter . Is there a gasket or seal or perhaps a new spring to make this seat right? Doesn't do it all the time but frequently. I am assumung it is the resevoir and not an internal hose because it stops if I remove the resevoir
  • 515 Answers
you have to replace the gasket in your water inlet, if you look where the inlet is you will see there are a little gap between the chassis and the inlet.
Take a screwdriver and bend up the plastic, you will now see the gasket.
The gasket have spare part number: 145842900
Hope this will help you.
/Mirran
Posted on Aug 16, 2008
Saeco Vienna machine...after brewing a couple of cups of coffee, water leaks from somewhere and comes out underneath the front grilled tray and onto the counter. Can I do the repair with the proper parts?
Depending on your ability to do some technical and minutious manual work, unmounting and remounting the machine is feasable.
Concerning the leaking, what I've seen most is a leak from the seal under the water tank. Any leaks coming form there would occur even though no coffee would be dispensed. (i.e: Idle mode)
If leak is ONLY occurring when brewing cofee, I would check the following:
1- Check if the water inlet on the back of the brew unit is filled with residue (the inlet looks like the end of a smoke pipe)
2-Open the machine, take out the interior, and verify the water tubes coming in and out of the boiler. They both should be sealed with 2 small o-rings. After time, o-ring tend to expand under heat and may start to leak.
Hope this helps
Feb 27, 2011 | Saeco Vienna De Luxe Espresso Machine
I am losing coolant, not from the radiator and not from the resevoir, where else could it be coming from. The resevoir is empty in 1 week after fillup
you could have a blown head gasket and coolant could be leaking into your combustion chamber.
rent a radiator pressure tester and see if the cooling system will stay at constant pressure. If the pressure drops you have a leak, and it could be your gaskets. pretty costly to repair.
make sure you have not blown the seals on the engines water pump. when they go out, the burst disc on the pump open and gush coolant everywhere.
Dec 19, 2009 | 2004 Pontiac Grand Prix
Over heating and anti-freeze spilling out of resevoir tank. New thermostat, new water pump, new resvoir tank, radiator 1 year old, new gasket seals. Can not figure out why it is leaking.
Your head gasket has blown or the cylinder head has crancked.You are getting compression in the water system thats why you are getting spill out from resevoir tank.
Jul 29, 2009 | 2000 Ford Taurus
Saeco Trevi leaks from "inside"
What can have happened is that through an overflow of used coffee the hole in the back is stuffed with the ground used coffee. The way to solve this is getting out the brewing group and rinse the hole with water after removing the cloggin coffee residu. You can find this hole just beneath the outgoing axle.
Mar 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Coffee Machine water leak
I have had the same problem with my Saeco Digital & Saeco Superautomica machines. After much work and somewhat expense I have finally found a simple fix. All you need to do is replace the gasket which is located just under the water reservoir.
(1) Take the water reservoir off
(2) Pop the round plastic piece located in the middle off (don't worry you won't break it as is it pretty tough)
(3) Take the black rubber gasket out and either:
(a) cover the present gasket with the brew group lube or
(b) replace the gasket with a new one.
which will give it a air tight fit and prevent any further water leakage from the reservoir.
You can get a new gasket for $5!!! :) I got mine at: http://cerinicoffee.com/item.asp?cID=0&PID=90
I also put some Brew Group lube ( http://cerinicoffee.com/Lube_brew_group_saeco.asp ) around the gasket as a temp fix until I completely replaced to gasket. Apparently, what happens is that the original gasket gets old, dry rots or whatever allowing the water to leak out of the reservoir. And then all over your work surface. The Saeco machines are quite intricate but are
Hope this helps.
-Dave
Nov 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
There are no screw to be removed, you have to take off the plastic ring in the water inlet. Take a screw driver and set it between the chassis and the water inlet.
/Mirran
Aug 21, 2008 | Saeco Vienna De Luxe Espresso Machine
Contact Saeco USA and see where they have a local service for Saeco.
Saeco USA Inc.
7905 Cochran Road Suite 100
Glenwillow, OH 44139
Tel. 440-528-2000
Fax 440-542-9173
E-mail: info@saeco-usa.com
Visit the Web: www.saeco-usa.com
/Mirran
Aug 17, 2008 | Saeco Vienna De Luxe Espresso Machine
Milk island seems to leak water. After milk is frothed and island has been detached fro some time, a pool of water forms under the base of the milk island attachment and on top of it.
Milk island on a vienna class?
Perhaps its a Saeco Talea you have, correct?
First remember that after foaming your milk and have turned the knob back to´off location. wait until you hear a clicking sound from the machine, might take 2 -5 seconds after it set to off.
Then remove the milk container
That sound means it has close 100% and shouldent leak.
If it still leaks after that its the gaskets in the T-pipe that needs to be changed.
Jul 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso Machine Logo
131 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
