Question about Grundig Xephia 42 in. EDTV-Ready Plasma TV
Have a problem with picture on 42" Grundig Xephia PW1106606TOP. There is picture ,but shades (hue) of all 3 colours ar very bad and picture is much darker than it should be. All voltages on all boards are OK ,sustain waveforms on y-sus and z-sus board - OK (tested with oscilloscope). Picture is much darker if video signal comes via SCART then if it comes via composite IN (chinch ,AV3) ,but it's not even close to a normal picture ,HDMI doesn't work at all. I belive that problem is on main board but I'm not sure which part on board make problems.
4 Suggested Answers
muntejaya
  • 10421 Answers
SOURCE: Grundig Xephia 42PW110-5510 TOP i was watching it
Hi, There are shorted parts inside your TV. If you able to check the TV, please check all power line with OHMMETER. Investigate the capacitor and others from deformed and damaged. Replace the broken parts with existing type. If you are not know how to repair, a local TV repair shop is an option.
Regards
Posted on Jan 01, 2011
Testimonial: "thanks, will have to look into taking it to a tv repair shop."
ginko
  • 19396 Answers
SOURCE: No sound on a 21in
Hi.
Using AV entry ensure that the red/white leads have been connected properly to TV Audio input. SCART is supposed to have built in sound. Test using a different scart.
Try disconnecting power cord for fifteen minutes, that will discharge internal component and reset the TV. Double check audio settings just in case.
If all that does not help, then the problem is likely the sound circuit inside TV. In this case the audio circuit is built-in the main board. Usually with the 19'' LCD TVs you need to replace the main board. Parts for this model are not available from third party distributors. In case the TV is defective, I suggest calling the Grundig number listed on your owners manual to arrange repair or to check part availability. To find contacts you can also use the 'International' tab on top of this page:Welcome to Grundig.
Regards.
Ginko.
Posted on Apr 11, 2011
casperaugust
  • 85 Answers
SOURCE: grundig elegance 72 flat screen problem
sounds like frame collapse check out repair costs as can be rather expensive
Posted on Dec 01, 2012
What are signs of picture tube going?
Signs of a CRT going old, are bad focussing, unnatural colours and hues of a certain colour (red, green, or blue) if you watch black/white pictures. In colour pictures, black sequences also show hue.
Jun 13, 2014 | Panasonic CT-32SL14 32" TV
Grundig Xephia 42 in.stuck on stand by
Probably the internal power supply has failed.
Nov 22, 2013 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Grunding TV not starting
Problems start from the power board.For easy fix, replace the board with the same type.Or if you didn't know what to do, call the Grundig Service Center for further assistant
Aug 23, 2011 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
The TV doesn't start, the RED led flashes a click sound is heard and then LED switches off. This goes on and on and on
The problems starts from the power unit, on this board, the voltages needed to operated TV normally dropped down very low.And one of the power resistor/ Integrated Circuit burned.
To fix this,you need to find someone who capable to repair this board or took it to service center.
Hi, Please somebody help me. I repair a faulty grundig plasma tv. At first it has no picture because the STK795-820 (YPPD) IC and the fuse was broken. I changed these and now it works, but the picture is...
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 30, 2017 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Regards
Jan 01, 2011 | Televison & Video
I want the address for grundig uk
Grundig UK Ltd, Elstree Business Centre, Elstree Way, Borehamwood, Hertfordshire, WD6 1RX
hope the helps
Nov 09, 2009 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Sounded like fuse blown up, replaced fuse in power plug, power on but no service?
i think it might have damaged the internal parts. but sometimes, certain devices drop down as a safe measure when fuse gos out. reseting it might help. good luck!
Oct 14, 2009 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Grundig Xephia 42 in. EDTV-Ready Plasma TV Logo
69 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
