Question about Flotec Fp4332 1 Hp Convertible Jet Pump ()
How to increase water pressure on flotec fp4332
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: how do you adjust the water pressure on a flotec
You can not adjust the 'water pressure' the pump delivers but you can regulate the flow by installing a valve on the pump discharge and then partially closing it to reduce flow and increase pressure.
Posted on Jan 08, 2010
How do I increase the pressure on my Flotec FP711OT-08. It is low 40s psi, can I move it up to 50 psi or high 50 psi? Water pressure throughout the house is low.
There may be a pressure setting on your outfit but My feeling is -- your problem will be low pressure on your water line. Most pressure settings is to keep from having too much pressure on what your running. For instance our city water pressure is 70 lbs but in order to keep my furnace boiler system at 16 lbs I have to install a pressure reducer.
Nov 23, 2014 | Pentair Flotec Fp7110t-08 Water Tank...
Have Flotec pressure tank style fp7120-08 .Pressure gauge with nothing running goes up and down constantly. I've drained the water in house shut off power to holding tank znd there is no pressure
check the foot valve for leaks it at the end of the pipe in the well also if its newer than 30 years there is a cupler where the horizontal pipe meets the vertical on at the well head
Apr 24, 2012 | Plumbing
Pump will not prime.
Pump self primes after the housing is initially filled with water. Failure to do this will reslut in the unit not drawing up the water and could potentionaly damage the unit.
Aug 25, 2011 | Flotec Fp4332 1 Hp Convertible Jet Pump ()
My flotec 1/2 hp shallow well pump pumps to 45# of pressure rapidly, takes longer to get to 49# pressure and then takes 30 - 45 minutes to reach the 50 psi shut off pressure. The pump is hooked up to a...
Those pumps will reach 50# when brand new, but soon the parts wear and then they will not make that pressure anymore...
Instead of replaceing the pump, just back the pressure down a tick or two to get it to shut off and not waste your electric....
Well Pressure Switch Adjustment Water Well Problems
heatman101
Jan 03, 2011 | Flotec Corrosion Resistant Shallow Well...
How do i set the low pressure on the flotec switch
your pump should have a 20lb seperation ie. pump turns on at 20lb and off at 40lb or on at 50lb off at 70lb. under the cover of the switch theres two screws with springs under them.dont mess with the small one.the large one if you screw it down (right) will increase the pressure while maintaining the 20lb separation. one thing to keep in mind its fine to adjust the pressure BUT at the same time the air pressure in the tank needs to be adjusted to two lbs below the cut in pressure of the pump.
I believe the directions are in the top of the cover of the switch
Jan 02, 2011 | Flotec TC2151 P2 Well Pump Pressure Switch
My flotec pressure tank seems to be waterlogged, how do I recharge it?
I don't know your model. Generally, a newer pressure tank has a flexible bladder that separates the water from the air charge. If you have water on the top of your tank, the bladder has broken. It seems that Flotec tanks have replaceable bladders. Flotec Pressure Tanks
That is a link to a company that sells parts for theses tanks.
Gary.
Dec 04, 2010 | Electrical Supplies
I have a flotec shallow well pump i can not get it to pump the water it stays at 20 pounds did i hook it up wromg
check your pressure tank. It sounds like it is water logged. This means there is no air pressure in it. If you're cut in pressure is set at 30 pounds you must have 30 psi of air pressure in the pressure tank.
Oct 01, 2010 | Flotec 3.4 Hp Floodmate Submersible Sump...
How do you adjust the water pressure on a flotec fp4012-10 water pump?
Jan 08, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Flotec Sprinkler Pump not priming
it might be that the pump is prewired at 230 volt and you are running a 115 power supply to it, if motor just humms and little water comes out this might be your fix
Mar 13, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Low water flow
sounds like air is trapped in the system somewhere. that is why any pump will surge. check the lines going in to make sure it isn't sucking air somewhere along the way and make sure the discharge line is clear so it can pump out fully.
Jan 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Open Questions:
Flotec Fp4332 1 Hp Convertible Jet Pump () Logo
152 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ryan Ross
Level 1 Expert
Are you a Flotec Garden Expert? Answer questions, earn points and help others
