Question about Kitchen Ranges
Sd code Model wtw 6200sw0 console lights flashing.checked drain and rec.pumps for obstruction appears clear hoses ok what else can i check.
  • 1 more comment
  • ivo arias May 29, 2011
    checked both drain and rec. pumps all is clear.but found that drain pump impellar does not turn freely rec. pump turns very easily but the drain impeller turns but with a little tension,is this normal or should the impeller shaft also turn freely on the drain pump
    ok i believe that is the correct solution i have ordered the pump assembly,waiting to comfirm that this will solve my problem,
    thanks i will.enjoy the Holiday
  • 710 Answers
Hi iarias50,
You get an sd code when the motor drive becomes overloaded. Commonly, this will happen when too much detergent is used. If you think this might have been the cause, run the rinse cyle and then the regular cycle without detergent and see if this clears it up.
If not, then there are other things you should check if you have the equipment.
1. Check the pump filter and then check the pump to if it is operating.
2. Check the wiring harness and all its connections to be sure they are secure.
3. Check the pressure switch to see if it good, and
4. Check the central control unit
Good luck.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on May 30, 2011
    President:
  • 2,047 Answers
If you have checked all the hoses and yet the problem persists then this is possibly ? sensor problem. Simply clean the entire unit and reset the unit from the pcb (power circuit breaker) this you can do by turning off the power supply to the unit for about 5 mins and then turning the unit back on after. This should reset the unit if there is no blockage or obstruction. But as I said earlier do this only after all the pipes have been examined and determined to be free. Hope this solution has been helpful?
Posted on May 29, 2011
  • Kitchen Ranges Master
  • 1,902 Answers
Hello & Welcome to FixYa
Sd error means suds lock which means that overdose of detergent is detected during the wash cycle. First run the unit through a RINSE/SPIN cycle and then run a normal cycle without adding any detergent. After this check the drain hose and clean it for any blockages, after this check the wire harness connections to the drain pump, pressure switch and Central Control Unit(CCU). Please get back to me if you have any other questions.
Kevin
  • 1 more comment
  • Kevin White
    Kevin White May 29, 2011
    The pump assembly needs replacement as its not working correctly.
  • Kevin White
    Alright you can give a 4 thumbs rating if this was helpful and get back for any other questions.
  • Kevin White
    Sure you can....please give a 4 thumbs rating if it was helpful and get back for other questions
The washer stops at 39 minutes on a regular wash cycle and the code OE is displayed
This fault code can mean that the pump is faulty as well as blocked, first of all check for a blockage and, if none is found then the likelihood is that the drain pump is faulty. Should you need it, the most common drain pump used on LG washers and washer dryers is this one.
On non-display panel models this fault code is denoted by the lights for 800, 500 and No Spin being lit or flashing.
  • Check pump filter is clear and there are no obstructions
  • Check the drain hose for obstruction
  • Check the drain hose is not kinked
  • Check the drain pump filter and clean if required
  • Check the air chamber and pressure sensor hose
  • Check drain pump, normal resistance is 152-175?
  • Check drain pump rotor
  • Check connections to water drain pump
Oct 09, 2015 | LG WM2701HV Washer
Samsung DMT - 400 delicate light blinking
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Sd is appearing on the screen? what does that mean?
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Sep 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does SD error code mean on Kenmore HE 2 plus front loading automatic washer
Hi
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
What is coed Sd
Hi
Daniel
Aug 27, 2011 | Washing Machines
What does errror code SD mean. My washer also will not drain all the way.
Hi
Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Apr 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Display says sd
Hi
Daniel
Jan 27, 2011 | Kenmore HE2 Plus Front Load Washer
Sd error display. Not slow draining
Hi
Daniel
Dec 15, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water left in machine, not emptying, light flashing
you may have an inefficient or partially blocked water pump remove drain hose and check if there is an obstruction if so clear it and re attach hose try draining machine listen to water flow if strong ok if not you still have an obstruction or faulty pump if no flow at all pump or control failed on final drain hope this assist you
Nov 05, 2009 | Bauknecht 24 in. GSX7551 Built-in...
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
