Question about Microwave Ovens
I have an NEC N920E Microwave. The turntable no longer turns. I am a licenced electrician - can I fix it?
  • 1,056 Answers
Sure you can fix it. The turn table just have a small motor inside and some gears. Remove it and check the motor for contitunity and also check if the wire leads getting power when the oven is on. Most of the time the motor is hard to repair and not worth your time so it is best to replace it, it has enamelled wires as thin as human hairs. lol
Posted on May 28, 2011
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
Nov 13, 2013 | Microwave Ovens
GE Spacemaker microwave turntable no longer turns. Microwave still heats, but turntable has stopped working. What are likely causes? And is this something I can attempt to fix myself?
This is a common problem the turntable motor has failed, it can be replaced.. but Microwaves are VERY dangerous. Due to the enormous energy stored in the main Capacitor, this MUST be discharged to earth B4 attempting any repairs. apart from that though should be easy enough. I do recommend a reputable service center/man tho.
Jan 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating
OK, you have two components that are faulty. the magnetron and the turntable motor as well. replacing these two components will fix both issues.
Jun 10, 2009 | Frigidaire FMV157GM Microwave Oven
The microwave was accidentally used without the glass turntable
It mkay just be the overload fuse inside the back panel. I highly recommend a certified electrician or repairman to change this. Good luck
May 11, 2017 | Microwave Ovens
Microwave turntable motor or belt?
I assume you don't have an illustrated parts list try and Google one up using make and model number etc. It is also a good guide on what needt to be removed and in what sequence.
As far as the novice part, the turntable is a basket case now what can you hurt, this is how we all learned, try to fix it if you cant then call someone who can, not a big deal.
Feb 28, 2009 | GE XL1800 1100 Watts Microwave Oven
No longer turns
on the bottom of most units you can get to the turntable motor with some side cutters,cut the joins. pull the little flap off and there is your motor run a current through it to see if it turns(how much will say on the motor) if not turning there is your problem
Oct 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not work
If the rest of the oven works fine, then this indicates that you might have a problem with the motor that turns the turntable.
If you try to turn the turntable manually (gently), does it turn freely or is there resistance? If it turns freely, the mechanical mechanism between the turntable and motor may be broken and the motor may be ok.
The oven's microprocessor also controlls the motor. There could be a problem there.
You'll need to have it looked at by a service center. Although its not that difficult to determine which of the reasons I mentioned above is the cause, it can be however, dangerous to operate a microwave oven with the cover off and with high voltage circuits exposed.
Please let me know if I can be of further assistance to you.
- Jim
Mar 08, 2008 | Goldstar MV-1526 Microwave Oven
Turntable no longer turns
That would be the turntable coupler.
For more help from Emerson : http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Nov 25, 2007 | Microwave Ovens
Turntable roller rest
It's called either the turntable coupler or the turntable support, depending on your model number. You can visit the Sears parts Web site at http://www3.sears.com/ and enter your full model number and see exploded view diagrams, parts lists, and order the part. Or you can call Sears parts at 1-800-252-1698.
Mar 24, 2007 | Kenmore 62463 Microwave Oven
Microwave Ovens Logo
110 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
