Lennox air conditioner. Outside unit fan stopped spinning. Air coming out inside the home. Unit is on and operating. Fan just stopped. What is wrong and what should i do?
    Genius:
  • 1,033 Answers
Hello, this sounds like a bad capacitor or bad fan motor. Replace the capacitor, if replacimg the capacitor does not work you have a bad fan motor. Capacitor is usually about 10 bucks where a motor is about 200. So try repacing the cap first.
Posted on May 28, 2011
Ruud. How do I repair?
It is likely that the fan will have to be replaced.
Jul 13, 2015 | Heating & Cooling
Lennox 10hpb
change run capacitor on fan. or bad fan motor
Jul 06, 2014 | GE Zoneline AZ38H12DAD Split System Air...
I have a lennox ac unit model M/n hs 29-029-2p S/n 5802g 11144 the fan just stop working and the motor was making a noise like it was humming plus no cold air was coming through our house we purchased it...
The fan stopped working and the compressor overheated due to this. Turn the disconnect (switch by outside unit off) and let cool.
Try spinning the fan by hand. If it moves freely replace the capacitor, if not replace the motor.
Aug 21, 2011 | Heating & Cooling
I have Carrier 38TKB036 3 ton A/C condensing unit and one 28CCA036 3 ton A-coil to provide A/C to home thru existing furnice. A/C was on and stopped working. Turned off/on, but will not come on. Any...
Is the furnace fan (indoor fan ) running. If not the problem is with the inside unit. It supplies the control power to operate the entire system and has a control fuse on the circuit board. If it is running but not the outside unit then the problem is outside.
Aug 08, 2011 | Carrier 38CKC042 Air Conditioner
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
Lennox central air for home not kicking on. Fan on the outside not spinning but motor is making a humming noise. No cold air coming in home. We have circuit breakers they are turn to the on position. ...
Is the indoor fan working? The problem with the outdoor fan sounds like it could be your capacitor. Turn off the power to the outdoor unit and make sure the fan turns freely using a screwdriver or something that will reach the blades. If it turns freely then it is probably the capacitor. Let me know what you find.
Aug 25, 2010 | Goodman CLT36AER36 Air Conditioner
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
Lennox air unit not blowing cold air
your fan motor outside is going bad, have a service company change it out for you.
the motor stopped working and that overheated the compressor shutting it down on thermal cutout, and it will only come on once it cools down
Jun 16, 2009 | Heating & Cooling
Lennox air conditioner is blowing hot air
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Jan 29, 2009 | Heating & Cooling
External fan stops operating in hot temperatures
Replace the motor on the outside fan, It should run all the time.
Jan 07, 2009 | Heating & Cooling
Heating & Cooling Logo
328 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
