ZT Group Cisnet  PC Desktop Logo
Posted on May 28, 2011
Recovery f key - ZT Group Cisnet PC Desktop
Anonymous
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on May 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
5387
Points
65
1helpful
I need a gateway laptop recovery cd
Gateway does not provide recovery CDs for their laptops. Instead, they provide a recovery partition on the hard drive that can be used to restore the laptop to its original factory settings. To access the recovery partition, you will need to press a specific key or combination of keys when the laptop is first turned on. This key or combination of keys will vary depending on the model of laptop you have. You can find instructions for accessing the recovery partition in the laptop's user manual or on Gateway's
4answers
My pc don't see my hard drive. Thought to go to some data recovery services, but here is the problem - this hard drive is encrypted and I don't remember the password
It's always a chance. It's hard but possible. It's will depend on what type of encryption is used and how did you "broke" the drive. If in some recovery service they say they can't do it , you should try at least few more, because I know for sure that it is possible . This guys definitely can do it - www.datarecovery.net - look, maybe there is office in your town.
Oct 16, 2018 • Cell Phones
3answers
How can I factory reset my surface pro without bitlocker recovery and password?
I call microsoft about your surface pro and they should help, is your surface still under warranty
2answers
How can i reset a toshiba satellite pro m15 s405
Most Toshiba laptops with come with the factory software recovery image stored in a special hidden partition on the hard drive of the laptop. The factory software recovery image allows the user to recover the laptop to its factory fresh condition as when it was new.
This partition may also be referred to as the Partitioned Recovery Method or Free Recovery option.
IMPORTANT: The recovery process deletes information stored on the internal storage drive. Be sure to save your work to external media before executing the recovery.
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. On machines with the F key numbers on the top edge of the keys and in White:
    • Press and hold the 0 (zero) key and power up the laptop.
    • Release the 0 (zero) key when the recovery warning screen appears.
    On machines with the F key numbers on the bottom edge of the keys and in Gray:
    • Power up the laptop.
    • When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu.
    • Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
  5. The TOSHIBA recovery wizard warning screen appears stating that when the recovery is executed all data will be deleted and the original factory software image will be rewritten. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. After you are sure you have everything you want from the laptop saved, click Yes.
  7. When the Toshiba Recovery Wizard opens, the default and recommended option is "Recovery of Factory Default Software".
  8. After selecting your desired recovery method, select Next.
  9. On the next screen you may have recovery method options. The default and recommended method is to Recover to Out of Box state.
  10. Select next to continue.
  11. Follow the on screen instructions as you navigate through the system recovery steps.
  12. The laptop will restart multiple times and install the needed components.
What is Card recovery Registration Key,
That means you need to buy it. After buying, they will send you the key.
Acer Aspire One 521 does not boot. When holding down power button - battery charging light goes out and when I hold ear near power connector, I hear clicking noise every 2 seconds. Have tried taking...
To start the system recovery:
  1. Restart the netbook.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. In order to recover the system using Acer Recovery Media, an external optical disc drive is required.
  2. When the Acer logo appears on the screen, press the F2 key repeatedly.
  3. Press the Left Arrow key until you've selected Boot.
  4. Ensure that the external optical drive is plugged into a USB port.
  5. Refer to on screen instructions to set the first device to USB CDROM.
  6. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  7. Close the CD-ROM tray.
  8. Press the F10 key and then the Enter key to save the changes and restart the netbook.
  9. The computer will boot from the Acer Recovery Media
  10. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD. Note: If there are multiple Recovery CDs, please insert the first Recovery CD.
  11. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media you may purchase recovery media online. If your computer is unable to run the Acer Recovery process, or errors occur during recovery please contact Acer Support.
How do you restore it
All HP's and Compaqs (as far as I know) come pre-installed with a recovery partition. This replaces the functionality of a recovery CD or DVD, only without the hassle of losing or scratching a recovery CD or DVD. There is one drawback to this method; namely that if the hard drive (or more likely for you) solid state drive gets damaged or erased, you run the risk of also erasing this recovery partition. If this happens, you will need to go to HP's website to order a recovery USB key. Information for ordering a recovery key can be found here. Keep in mind you can only order one recovery key per system, so if you do have to take this route, be sure to create another using the information at the bottom of this post.
  • Press the Power button to start the PC, and then press the f11 key when the standard BIOS prompts are displayed on the black screen.
    NOTE: Pressing the f11 key during startup on a computer with an HP factory image will start the system recovery process even if the prompt is not displayed.
    • If the HP Recovery Manager can access the recovery partition on the hard drive, a prompt to backup the user files before beginning the recovery is displayed. Follow any on-screen instructions.
    • If the HP Recovery Manager cannot access the hard drive to fix any system errors, you will need to use the personalized recovery disc that you created to recover the hard drive to its original condition.
    • If you have not created the personalized recovery disc, or the discs are corrupted, you can order a replacement recovery disc from HP.
  • If prompted to use the Microsoft System Restore program, click No , and then click Next .
  • When prompted, if you want to backup your personal files and settings, select the Back up your files first (recommended) option, and then click Next . Follow the on-screen instructions.
  • When prompted to Recover without backing up your files , please STOP before clicking Next . WARNING: This is the final opportunity to change your mind about recovering the PC and deleting all the files and programs. Once you click Next , the restore process cannot be stopped.
  • If you are satisfied that you want to begin the recover process, click Next . The PC immediately begins formatting the hard drive and destroying all data.
  • The recovery process may take up to several hours and will return the PC to its original condition. Any custom settings, drivers, software programs and updates, and/or hardware updates are lost and must be reinstalled.
    Once this process is complete, you can create a recovery USB drive using the procedures outlined below:
    There are three options for recovering these mini notebook PCs to their original operating system image.
    • Option 1 - Use the Recovery Manager program on the recovery partition on PC. For Windows 7, turn on the power switch, press Esc key at boot followed by F11 key for the recovery menu. For XP, press F6 key for Roxio BackOnTrack utility.
    • Option 2 - Create a personal set of recovery media. For Windows 7 and XP use the HP Recovery Manager to create a recovery image on either a DVD or an 8 GB USB flash drive). For XP, use Roxio BackOn Track to create a recovery image.
    • Option 3 - One-time purchase of the Recovery USB recovery key.
    The USB Recovery key can be purchased from the HP web site. The USB key is larger than normal thumb drive. HP can ship only one USB recovery key per unit.
    How to restore accer to factory settings
    Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer.
    IdeaPad S10e Netbook: CANT OPEN LENOVO ONE KEY RECOVERY UPON START...
    Make sure you did it correctly. Computer should be OFF when doing the one key recovery. Turn off the computer then press the small button right beside the power button. Your computer should automatically turned on and you will go straight to one key recovery software. If this will not happen, then the one key recovery is destroyed. We need to re-image your Harddrive to have that one key recovery software back to you computer. You may call Lenovo technical support department for further assistance on how you are going to send your laptop to our depot department.
    If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
    Top ZT Group Computers & Internet Experts
    Jose Ramirez
    NOEL
    NOEL
    Steve Sweetleaf
    Steve Sweetleaf
    Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
