Question about Troy-Bilt Garden
I recently purchased a Troy-Bilt trimmer (mdl # tb575ec) & the operator's manual was missing some pages, including the page that describes how replace the trim line. I have been trying to download a copy of the manuel for this model, but to no avail. It's a big mess in trying to download. The SN is 1g230dz1287; the part # is 41edt57c966. Please give me specific directions as to how I can download a copy of this document. THANKS!
  • 41 Answers
SOURCE: TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
Posted on May 07, 2009
bbreton
  • 437 Answers
SOURCE: Troy Bilt string trimmer starts but dies when I
Try mixing up some fresh gas mixture if it is over 30 days old it is considered bad gas. Or the carburetor may need to be rebuilt.
Posted on Sep 30, 2009
dontbother10
  • 2220 Answers
SOURCE: Need manual for Remington Limb & Trim 8, Model
I tried the numbers you provided and none crossed.
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
The most complete owners manual is "M15012US (and several others)" viewed as explainewd above. Page 9 discusses oil weights. Standard bar oil is 30 weight non detergent with addatives to help it adhere to the bar. That would be my recommendation. HTH
Lou
Posted on Jan 16, 2010
SOURCE: Need info on putting line on troy bilt 4-cycle
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Posted on Apr 05, 2010
dontbother10
  • 2220 Answers
SOURCE: I am trying to obtain a copy of McCulloch 338 Chainsaw Manual
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322
Include your e-mail address in your request.
Posted on Apr 09, 2010
Model TB425CS WHAT IS SPARK PLUG GAP
Al, .025" is the plug gap for your trimmer,page 20 in your manual. There may be a recall on your model to do with safety.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss.html
Troy Bilt Model TB425CS Parts
Troy Bilt String Trimmer Sold at Lowe Recalled for Laceration Hazard
May 15, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Gas dripping out of air intake on troy bilt trimmer TB525EC
The diaghrams in the carb could be starting to stiffen up holding the needle open. Does it start with no choke when cold? Rebuild the carb to replace stiff diaghrams
Oct 24, 2012 | Troy-Bilt 4 Cycle Straight Shaft String...
Troy Bilt TB575EC cutting head hard to load, now doesn't spin.
Remove the cutting head spool and see if you have old grass stuck around the shaft area that could be causing to cease your shaft..
Mar 03, 2018 | Troy-Bilt 4 Cycle Straight Shaft String...
Troy bilt chipper/vac model 47287 manual
I bought a bad photocopy of the Operator manual from a seller on eBay, and put it online:
[URL="http://asavage.dyndns.org/Troy-Bilt/"]http://asavage.dyndns.org/Troy-Bilt/[/URL]
It\'s not great quality, but it\'s better than nothing.
I\'ve got some parts manual pages there, too. Also of dubious quality, but you can make out the part numbers.
Mar 24, 2012 | Troy-Bilt Chipper Shredder
Whats the gap on the spark plug on troy bilt tb20cs
Hello, Johnny -
The correct gap is .020" (0.5mm).
Link to specification page in owner's manual attached.
Troy Bilt TB20CS Operator Manual Specifications
Mar 06, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I am trying to replace the head on my TB575EC trimmer but can't remove the black inner spool. Any suggestions?
Unscrew the head's center bump-knob counterclockwise with your fingers. Pull the bump knob off and take the spool cover off the head. Slide out the spool and any remaining cutting line. Lift out the spring underneath the spool. Take out the slide washer. Unscrew the arbor bolt either clockwise or counterclockwise, depending on model, in the center of the trimmer head using the wrench. Take the entire head off the end of the shaft.
Sep 03, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Purchased a Troy Bilt Edger model# 258-554E011 with Briggs & Stratton 5HP engine. Owners Manuals were missing. Can you send me one?
Hi sheets calvi...
I have found a webpage that you can download a free user manual for your Troybilt 258...
Go to the following webpage download and print out (so you have a hard copy).
Please take time to rate me
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/258.html
Aug 17, 2011 | Troy Garden
Where can we find help to install the head on a Troy Bilt weedeater trimmer TB20CS?
You will need to look at page 9 of the manual here. The string head installs part by part on the end of the driveshaft. If you are having trouble with the driveshaft turning while attempting to put the head on, post back. You shouldn't though if the end of the shaft's threads are in good shape. If you need to, spray some WD-40 on it prior to installation. Here is the manual.
http://dl.owneriq.net/c/c5ca28a7-c6a8-4dd0-8987-53c89193794e.pdf
Jun 08, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do i replace the line in TB575EC trimmer?
Your manual will have diagrams and instructions in detail for restringing. You can use the following link to get it.
Both the model number and the serial number for Troy Bilt Trimmers are 11 characters in length. In your case, 41ADT41C966 is the model number, not TB575EC. You will have to find and provide the 11 character serial number. Input both of these on the following page and a manual is yours.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001&langId=-1#
May 07, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I need a parts and owners manuel for a Super Tomahak Wood chipper made by Garden Way Mfg. Co. where do I go to get one?
Hi and welcome to FixYa. I am Kelly.
Go to this site:
http://www.brentchalmers.com/
I note your looking for the Super Tomahawk. If you can come up with a model number I think I can find your parts manual for sure. (or at least an on-line parts list.) Also.... If you can come up with an engine number like OH120 or L90 off of the engine I can find you a manual for the engine also.
This is the list of Manuals available there:
  • 1983 W-W Grinder Inc. Manual and Parts List Super Tomahawk 5-8-2G/C and Tomahawk 5-8-2G/M Chipper/Shredder (40 Pages)
  • 1989 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1989 Troy-Bilt Technical Manual 4HP, 5HP, & 8HP Models Tomahawk Chipper/Shredder (12 Pages)
  • 1991 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1991 Troy-Bilt Knife Kit number 1772231 (1 Page)
  • 1992 Troy-Bilt 5HP Model Service Kit (Part Nos. 1901153 and 1901804) For Chipper/Vac (1 Page)
  • 1992 Troy-Bilt Owner/Operator Manual 47260, 47261, 47271, 47272 Chipper/Vac (60 Pages)
  • 1993 Troy-Bilt Sales Brochure Chipper/Vac (4 Pages)
  • 1993 Troy-Bilt Owner/Operator Manual 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (44 Pages)
  • 1993 Troy-Bilt Parts Catalog 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (16 Pages)
  • 1994 Troy-Bilt PTO Chipper/Shredder Owners Dog Clutch Kit 1902404 (1 Page)
  • Hopefully your model is one of the above.
    Here is link to the Parts manuals:
    http://www.partsandservice.com/html/TroyBilt/cs/
    There are 90 parts manuals there.
    Again with a good model and engine number I can probably come up with your exact manuals.
    Thanks for chosing FixYa,
    Kelly
    Oct 20, 2010 | Troy-Bilt Chipper Shredder
    Garden Logo
    48 people viewed this question
    Top Troy-Bilt Garden Experts
    Jay Finke
    Jay Finke
    Jim Parker
    Jim Parker
    Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
