Question about Jacuzzi MAGNUM FORCE POOL PUMP 2 HP 115230V 94027120
1hp magnum pump starts for 3 to 4 seconds then shuts down. what could cause this?
3 Suggested Answers
  • 366 Answers
SOURCE: jacuzzi magnum force 1hp, pool pump. Motor has very loud noise
most likely the bearings are starting to go.
Posted on Jul 04, 2010
  • 31 Answers
SOURCE: 1hp magnum pump starts and runs but very little
Sounds like a problem with the impeller, take off the lid, take out the pump basket and reach down and feel past the opening in the bottom, should feel a smooth and clean series of plastic blades, it is possible the blades a chewed up or its loaded up with hair.
Posted on Nov 26, 2010
Pool Pump Runs Intermittently (~10 seconds on, ~1 minute off)
Need more info. What is the voltage at the pump? What voltage is the pump wired for? Sounds like your pump is shutting down from heat thru a safety. If the voltage is wrong the pump will heat up very quickly and a thermal switch will cut out, it will then cool off and try again. Get the readings at the motor connections NOT the breaker.
Apr 02, 2017 | AO Smith A O Smith Motors Century 1hp 115v...
05 Dodge Magnum went from 60 - 0mph in 0.0 seconds flat!!!
Sounds like you need a new key to me. When they start and die like that, the security system is not seeing a good key. This has to be done at a Dodge or Chrysler dealership. They can cut a new key and fob combo their as well as program them with their scan tool. It will cost about $200.00 to do this. The two cranks to start is a weak fuel pressure regulator. Probably located on the the fuel pump. May be serviced seperate now from the fuel pump assembly. Ask the dealer they will know.
May 20, 2012 | 2005 Dodge Magnum
1hp magnum pump starts and runs but very little flow. then pump shuts down. checked for water supply and any blockage . none found in supply or return pump is about 8 or 10 years old
Nov 22, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
My pump is no longer working my pool water is starting to turn green, I shut down the power but I can't seem to open up the pool pump to clean the basket can you give me any suggestions?
First get some liquid chloriene in the pool start with about four gallons. Loosten the lid ring then turn the pump on and back off after a few seconds. If your trying to get the pump housing open do the same thing with the lock ring that holds it closed.
May 06, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Hayward 1HP for in-ground pool: When I shut the pump off sometimes DE backflows from the filter through the pump and into the pool and accumulates on the bottom. The pump is about 10 years old and it just...
Usually caused by a small air leak somewhere on the pressure side of the system. A check valve on the line coming out of the pump going to the filter will solve problem.
May 05, 2010 | Hayward 1HP Super Pump II Inground Pool...
Pool pump starts & stops on its own outside of programmed run
There are several potential problems:
  • freeze protection circuit causing pump to start - could be a bad outside air temperature sensor.
  • It is possible the new relay is bad.
  • There could be a short in the control wires to the relay
  • old programming shadow stuck in memory (not likely since you changed the boards)
Yes, the starting and stopping can harm your pump.
Jun 04, 2009 | Pentair 1hp Whisperflo Pool Pump In -...
Pump does not turn on except for a humming sound and shuts off jumping the electric breaker
This could be anything from a stuck impeller to bad windings in motor. If you open the pump at the lock ring and remove the difusser from the impeller you can see if you can spin the impeller, If it won't move is it something holding the impeller up remove it. If notit is probally a bad bearing and you should replace the motor. If the Impeller turns try turning it on and caerfully try to spin before it kicks the breaker. If it is sort of stuck and does not want to turn the motor is bad and needs to be replaced. If it spins and won't start same thing, If it spins and starts it is probally a start capicator. Shut the power off at the breaker remove the back of the motor the capacitor will be a small black or silver cylinder with 2 or 3 wires clipped to it. Remove this and take it to a motor shop and get an exact duplicate. and that should fix it. When putting back together be sure to lube all "O"rings and refill with water. Hope this helps.
Jun 02, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
I have a Jacuzzi Magnum pool pump powered by an AO Smith Motor, 1hp, model #C48K2N117A9, serial #8599. Here's the problem. The control panel/timer, is on the wall next to the pump and I can hear it humming...
If the points in the timer are corroded the timer will run but will not put power to pump. If you have a volt meter you can ck this on the load side of the clock. If no power you just need to replace the clock. get all the info off the clock as you want the same brand for easy replacement but most brands have a virety of clocks that look the same and you want to be sure to get the right one. Mind wich wires are line and load since position changes from some old clocks to some of the newer ones. Be sure you shut the power off at the breaker before you start to replace anything.
Apr 09, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Jacuzzi MAGNUM FORCE POOL PUMP  2 HP 115230V  94027120 Logo
83 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
