Question about Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46
MOWING DECK WILL NOT "TURN
  • 659 Answers
A wiring diagram and a test light are needed. If you don't have the wiring diagram, use a test light, start at the clutch and work your way back checking for current at each switch/connector. It maybe the ignition switch, there should be one terminal on it that feeds 12v to the clutch curcuit.
could be your ignition switch but thats the best way to find out where its not getting power to.
Posted on May 28, 2011
  • Wesley Gardner
    Wesley Gardner May 28, 2011
    Could be the PTO as well need to be replaced. play around hopefully you find the culprit!
How to adjust mowing deck to mow field and why is my-right side lower then left side deck
you should be able to see adjustments under mower . without any idea what you have for mower its hard to say
but you can start by making sure tires are inflated equally
Sep 27, 2015 | Garden
Why can't I raise or lower the deck?
Sounds like you have jammed linkages which raise and lower deck, you can try this which usually works best with assistant.
With engine off, shake the deck vigorously (up,down, back and forth) while try to raise deck with lever.
Check for worn or damaged arms, springs, deck mounting points, etc and repair or replace.
Sep 01, 2014 | Garden
How do you level the mowing deck?
There should be an adjustment on both sides of the deck. Move the nut up or down to raise of lower it.
Jul 03, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
No engine power when deck engaged
dirty air filter on carb or spark plug might me loose lowering compression which will in turn rob your power
May 17, 2013 | Mtd Garden
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
Our indestructible deck has made mowing impossible, it clogs all the time and then "coughs" like it's dying. We have to stop mowing and turn off the blades and turn them on again to shoot the...
Hi and welcome to FixYa I am Kelly.
Maybe I am missing the obvious but I have had a couple of people that had this problem with since new use of a mower. One of them had the wrong blades with the deck and the 2nd one the baldes were installed with the air foil side DOWN. If you have Air-flow problems under your deck the above is possible or your blade deck drive belt is routed incorrectly. The decal for the blade deck belt routing should still be on your deck. Look at the decal drawing vs the actual routing of the deck belt. It is highly possible that one or more of your blades is driving backward.
If you can not find your decal (would be hard not to find it on a deck not 1 year old!), I will try and look it up but I need the model number of mower and the DECK (2 ea model numbers 1 for mower 1 for deck)
Thanks for choosing FixYa,
Kelly
Apr 22, 2011 | Garden
Why do grass get stuck in lawnmower than it starts to turn off
This can be happening from a couple of reasons, first if your grass is too damp this will happen with almost any mower, wait till the lawn dries out before cutting, you may be cutting the lawn when it is too high, try cutting it twice a week maybe this will help, you may try to raise the cut setting eliminating the amount of grass clippings that you have accumulated, if you are mulching or using the bag be sure the chute is clear, and lastly be sure you are running at a higher speed to push through the terrain.
Happy Mowing!!
Jul 14, 2010 | Mtd 22" Yard Machine Push Mower
Strange noise from deck of Toro LX426
The engine wont have an impact with the deck because its belt driven. It sure sounds like you have a bad set of spindle bearings,just turning it by hand you wont hear any noise it has to be going fast to hear it. The noise may be coming from your clutch instead of the deck,and it sounds like the deck. Have these things checked out.
Aug 09, 2009 | Garden
42" deck - uneven mowing in the center
yes its repairable & yes it can bend the spendle but most likely the blades is it one that does it or both blades or the center or the sides of deck is bent by stepping on the deck let me know if i can further help thanks wade
Jul 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46 Logo
211 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
