Question about Lincoln Plumbing
PUMP STROKES PER MIN MODEL 84902 & 84993 WITH MODEL 85300 HYDROULIC MOTORS
2 Suggested Answers
  • 98 Answers
SOURCE: ingersol rand model 3000, serial no 9835350,size
If the motor is a 20 horsepower it is pumping app. 80 cubic feet per minute . Here's a good rule of thumb 4 cfm per horse power.
Posted on Aug 06, 2009
18.5 hp lawn tractor will not turn over when on compression stroke . If you move it a little by hand past compression stroke it will start.
Sounds to me that you have a weak battery and is not putting out enough cranking amps..Takes more cranking amps during compression strokes to start than in down stroke...That is why you are able to start it in the down stroke less amps needed to turn motor over..
Jun 28, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Power consumption pool motor
Look at your amps and multiply by volts. This will give you watts.
ex.motor label 115V/14.4A 230V/7.2A
Whether you are running on 115v or 230v you get 1,656 watts.
This converts to 1.656 KW (kilowatts)
Your power company charges you by the KW hour. I'll use
12 cents per kilowatt hour for example.
$0.12 x 1.656 = .1987
This rounds off to 20 cents per hour to run, so if you run the pump 6 hour a day,180 hours per month, the electrical cost would be
about $36 per month.
Jan 09, 2013 | Pool & Spa
My 2 stroke pump has stopped working, while i get a new one does anyone know the feul oil ratio so i can keep using it pre mixed in the tank. please help thankyou
The standard mix is 32 to1. That is 4 ounces of two stroke engine oil per gallon of gas. Do not use motor oil in the gas. Please rate my answer. Thanks.
Apr 03, 2011 | 1994 Cagiva Mito 125 Evoluzione
I have a 1997 yamaha 500 vmax snowmobile that the oil pump is not working. And Idon't want to replace it, I just want to mix oil and gas. But I don't know the iol to gas mix . I have contacted several...
The standard gas/oil mix is 32 to 1. That means 4 ounces of two stroke engine oil per gallon of gas. NEVER use motor oil. Only use two stroke engine oil. Please rate my answer. Thanks.
Aug 12, 2010 | Yamaha V-Max Motorcycles
I want to know is it true that 4stroke motor uses only benzin or it can use benzin+oil? I have buy scooter ZN50QT-19 and i dont know which kind of fuel he uses :)He is 4 stroke
All four stroke motors use straight gasoline or benzin. Only 2-stroke engines use a gas (benzin) + oil mix. Even some later model 2-stroke engines run straight gasoline and have a pump that mixes the oil with the gasoline. Most 2-strokes built after the mid-70's have the pump. You can easily by examination of the throttle cable. If it's equipped with a pump, the throttle cable will split from one cable on down to two cables where it enters the engine. Read your owner's manual.
Dec 13, 2009 | 2005 Qianjiang QJ100-M
Ingersol rand model 3000, serial no 9835350,size 5.5"&5.5"&4"x4",would like to know pumping capacity per/min
Aug 05, 2009 | Air Tools & Compressors
Two stroke ratio
The standard ratio is 32 to 1. That equals 4 ounces of two stroke oil per gallon of gas.
Top rating Pls.
Jul 12, 2009 | 2001 Suzuki AX 100
What oil in crankcase of dt175 about 88 model
Use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell.
Use TWO STROKE ENGINE OIL in the pump. If not using an automatic oil pump, then mix the gas and oil 32 to 1. That equals 4 ounces of TWO STROKE ENGINE OIL to one gallon of gas. NEVER use motor oil in the gas. Only two stroke engine oil.
A “very helpful” rating for this answer? Thanks!
Jun 14, 2009 | 1974 Yamaha DT 360
I have a fimco pump on a 25 gallon sprayer. It is a 2.1 gallon per min. pump. I took it out yesterday to use and it would not pump up, no pressure. Worked fine last year. I checked and the motor is...
open up the pump, take out the check valve. wash in dish soap/hot water solution, scrub with old toothbrush, rinse off, reinstall & see if that makes a difference...
Apr 29, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Hi there i have a yamaha dtr 125 thats smokes
Assuming you are using two stroke engine oil, the pump is pumping too much into the gas. DO NOT use motor oil in the gas. If 2 stroke oil is being used, then get a new pump, fix the one you have or disconnect the pump and mix the oil with gas when you fill up. Four ounces of 2 stroke oil per gallon of gas equals the standard 32/1 fuel mix.
Apr 28, 2009 | 2003 Yamaha DT 125 R
Plumbing Logo
48 people viewed this question
Top Lincoln Plumbing Experts
Donni Steen
Tom Chichester
Are you a Lincoln Plumbing Expert? Answer questions, earn points and help others
