Question about Cycling
How do i remove cable from shifter - Cycling
    Brigadier General:
  • 8,546 Answers
Change shifter cable?
Year make and model helps. If you have a column shifter, remove the bezel and look it could be a clip or bolt the release the cable, then pull it threw the fire wall. On a console, you have to remove part of the console, or all of it to access the shifter cables. These have clips to remove and bolts at the floor pan to remove. Both are clipped to a mount on the transmission. Then there is either a clip or nut to remove at the selector lever.
Jun 15, 2015 | Cars & Trucks
My 2008 Chrysler Sebring shifter cable is broken how do I remove. The line out of the fire wall
That forum did not help at all. If it is a 2008 convertible I can show you how to take it out. First remove the radio bezel, then the console, then the shifter mechanism. At this point you can pull the shifter cable away from the mechanism. Now unplug the yellow connectors to the amp and then remove the 3 10mm nuts to the amp and remove the amp. Open the hood and take off the air filter assembly. Just one bolt and it pops off. Then pry up on the shifter cable end. If is probably already off as is why you are replacing it. There is a metal clip where the shifter cable attached to the mount. Stick a screwdriver under it and take it off. Do not lose it. Then just pry the shifter cable up from the mount. Pull it out from inside of the car. Takes about 20 minutes. Hardest part is the nuts to the amp. Good luck.
Jul 19, 2014 | Cars & Trucks
Replace shifter cable 1995 taurus
There's a grommet that is in the floor that the cable is attached to pop it out
Dec 28, 2017 | 1995 Ford Taurus
Shift lever won't go to park and moves stiff even while pushing on metal lever on the side of the transmission
The first thing i would do is to disconnect the cable at the lever on the ******, next move the lever at the ****** by hand and it should move by hand with little force. if the lever is hard to move then you may have a trany shift rod problem. next with cable removed try to go through the gears with the shifter , the shifter should flow with ease if its hard to move then its the shifter cable or the shifter itself. to find out which one you will need to disconnect cable at sifter and then move the shifter to see if its still tight. if the shifter is tight to move with cable removed then its the shifter but if it moves with ease then you have a bad cable. good day.
Aug 27, 2011 | Chevrolet 1500 Cars & Trucks
How do i repair shifting cable from cosole to trans.?
Welcome to FixYa.com
REMOVAL
1. Remove air cleaner and air intake hose assembly.
2. Remove center dash trim panel.
3. Remove center console cup holder assembly.
4. Remove floor console assembly.
5. Remove console side panels.
6. Remove Transmission Control Module ftMJ bracket.
1. Remove TCM.
8. Remove shifter cable from transaxle operating lever by removing nut and clip.
9. Remove shifter cable from shifter lever assembly by removing clip.
10. Remove shifter cable from shifter lever mechanism.
11. Remove cable from firewall grommet by removing grommet assembly nuts.
12. Remove gearshift cable from vehicle.
ADJUSTMENT
Lift and rotate the gearshift hand lever into the park (F9 gate position and remove the ignition
key. This confirms the shift lever is in the gated park (F9 position.
After confirming the park gate position. turn the ignition switch . If the starter will operate. the
park gate position is correct. Move the shift lever into the neutral (NJ position. If the starter
will operate in this position, the linkage is properly adjusted. If the starter fails to operate in
either position, linkage adjustment is required.
1. Park the vehicle on level ground and set the parking brake.
2. Place the gearshift lever in park (F9 gate position and remove key.
3. Loosen the cable adjustment screw at the transaxle operating lever.
4. Pull the transaxle operating lever fully forward to the park detent position.
5. Release the park brake, then rock the vehicle to assure it is in park lock. Reset the park
brake.
6. Tighten the cable adjustment screw to 8 Nm (10 inch Ibs.J. Gearshift cable should now be
properly adjusted.
1. Check adjustment by usinq the precedinq procedure.
Thank you for Using FixYa.com
Kind Regards, Lee
Your Master Technician FixYa Expert
Jan 31, 2011 | 1997 Chrysler Sebring
Broken shifter cable, how do i repair it
Put park brake on or block wheels, and shift into neutral (if possible), If not go to tranny and pop the cable off the tranny lever (pry off with screwdriver). Turn tranny shift lever, until it clicks twice, leave here for later adjustment. Follow the cable to the adjuster, pull out the flat steel retainer clip, pinch the sides to remove cable from bracket. Remove upper covers below the steering wheel. Remove kick panel below steering colomn. Remove cable from steering wheel shifter assembly (pry off and remove clip same as at tranny). Remove the side kick panel and follow cable along floor. You may find it easier to remove the driver seat (4 nuts on floor and wiring). Pull cable thru floor and replace. Reverse procedure to install. Lock the cable and clip at steering colomn, but leave the clip off at tranny. The tranny should still be in neutral. Now turn key to run and shift the shifter into neutral. At the tranny side cable there is a white square button, press in and lock cable to lever. install retainer clip. move shifter thru ranges and ensure it locks in park. Readjust if needed by pressing button and moving shifter lever on tranny.
Jan 27, 2011 | 1995 Chevrolet Silverado 2500
Not shifting properly
This problem could be related to bad cables or the linkage assembly.Remove the center console and get down to the shifter where you can visually see the cables,and where the cables attach to the shifter.The cables should be hooked up at the transmission,but removed from the shifter.One cable is the neutral gate position,and the other is the actual gear selector cable.Manually operate the cables and see if the gears will engage using the cables.If the cables work,you have narrowed it down to the shifter itself.If the cables don't work and gears can't be engaged using the cables,then the cables are bad.Also look over the shifter assembly visually,look for cracks or broken metal while shifting it through the gears.--------- Check it.Thanks.
Dec 07, 2010 | 1997 Pontiac Sunfire
2001 FORD FOCUS SHIFTER CABLE SNAPED
You did not need to remove the heater box to replace the cable. There is a hole in the floor the cable passes through.
Nov 15, 2009 | Ford Focus Cars & Trucks
Need to remove the cable from the 105 flight deck
This really depends on what cable you need to replace, the brake or the shifter.
For Shifter:
1. Shift the all the way down to the lowest gear using the small inside shift level for both the front or rear.
2.Disconnect the cable from the derailluer, likely a 5mm allen wrench will be needed.
3.Pull housing away from the shifter exposing the cable where it enters the shifter.
4.Compress the brake lever, this will expose a small hole on the inside of the shifter where the cable head is seated. For the right shifter the hole will be on the right, for the left shifter the hole will be on the left.
5. Push the cable in from where the cable entered the shifter. The head of the cable will now be exposed.
6.Pull the cable the rest of the way out of the shifter.
7.Install the new cable.
For Brake:
1. Disconnect the brake cable, likely with a 5 mm allen wrench.
2. Compress the brake lever. Keep it compressed until step 5.
3.Look straight in from the front of the bike, you will see the head of the brake cable.
4.Push the cable out of the shifter from the exposed area of the cable, then pull once you can reach the end of the cable.
5.Install a new cable.
Depending on the reason you have removed the cable, it is advised that you also replace the housing in most cases. For the shift cables this is not a problem, however, for the brake cables you will have to untape the bars to access the housing.
I hope this anwsers your question. Thank you
Jul 12, 2009 | Cycling
Cycling Logo
22 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
