Question about LG D5966 Gas Dryer
No heat during opertions - LG D5966 Gas Dryer
  • LG Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Jun 12, 2011
Will a 1987 Yamaha riva razz start with oil light on while trying to start it
check the oil level.If it is a normal engine lubrication set up the it will require oil pressure to put the light out which means that as soon as it starts or during cranking the light will go out and it will start. If the oil light is an indicator of low oil level then it will not start until you put oil in the emgine . Check the switch for correct opertion.
Oct 22, 2014 | MotoBatt 1987-2001 yamaha sh50 riva razz...
Acer az3730
press f8 during the boot up process then select the last known good configuration
Feb 10, 2014 | Computers & Internet
Miele t8322
I would suggest the limit switch sometimes located on the metal vent tube inside the dryer. The metal tube/pipe that exits out either the side or rear is the one I am referring to, has a high limt switch attached with 2 screws, sometimes this causes an open circuit.
Nov 03, 2013 | Ovens
Need operting instructions for THOR ST100X washing machine
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 07, 2011 | Washing Machines
Car gets to operting temp but no heat
If the car is not running hot or overheating the problem lies in the heating system. If it's overheating also more then likely a bad thermostat
It could be a number of things including the actuator isn't opening the door to allow the heat to enter the car, a pluugged heater hose, check all the fuses
Jan 23, 2011 | 2002 Saturn Sl
I have a 1989 Honda accord. I have an over heating problem. I changed the thermustat I checked the water pump and it was good. What could be the problem?
the most common problem is a leaking engine cylinder head gasket, this allows combustion gases to enter the cooling system and keeps the thermostatr from operting correctly, then it overheats.
Mar 06, 2010 | 1989 Honda Accord 4 Door
Air conditioner limodeght on ac control button
the a/c engages when defrost or perhaps bi-level is selected to keep seals in the a/c system from drying out.people don't normally operate their a/c in the winter. this operatin is normal. there might be a reference in your manual in the heating and cooling opertion instruction
Feb 26, 2010 | 2004 Pontiac Sunfire
Laundrette dryer producing no heat
Change out the igniter
Diamond Service
Apr 02, 2009 | LG DLE7177 Dryer
LG D5966 Gas Dryer Logo
53 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
