I have a thermacell that will not light, it is full of gas, and I can it spark when I push the igniter. Why wont it light?
5 Suggested Answers
  • 8 Answers
SOURCE: Car wont start, has spark and full tank of gas.
you need a starter
Posted on Jun 25, 2009
cadesertmax
  • 274 Answers
SOURCE: heater wont light
Perhaps the regulator is going bad, cheap and easy to replace. If not the regulator, then there is probably a blockage in the pilot assembly. If you don't use it for some time, and don't put it inside, or cover it, dirt and insects can get inside and cause a blockage.
You have to take the head apart to clear a blockage. If you are not comfortable with taking the head apart, hire someone to do it.
Posted on Jan 11, 2010
  • 120 Answers
SOURCE: Rinnai inbuilt lpg gas fireplace IB35ETR wont
You don't mention any error codes displayed. If this is the case I would start with a new main PCB. It should try and light for approx. 10 seconds and then go to lockout with an error code 11 if it was a gas supply issue. This is all controlled by the PCB hence my opinion on a PCB fault.
Posted on Sep 16, 2010
Testimonial: "Thanks for your input. Winter is coming and I will have a look at the heater this weekend. Good, clear advice. Thanks again."
  • 51 Answers
SOURCE: gwt501a won't light
To check the patio heater first make sure all the pipes/hose are clear, remove debris and check for insects, water and air. If these are all clear and the regulator is working OK then the most likely cause will be a worn thermocople, these wear out and are easy and cheap to replace. Found this site very useful for patio heater top repair tips.
Posted on Nov 09, 2011
Have a richmond 6G40-36F1 hot water heater had to turn off gas for another issue, now igniter doesnt spark and pilot wont light
Not to sound silly, but are you pushing the igniter button down hard enough so it snaps? If so, your igniter is no good. Try to light the water heater the old fashioned way by using a match. I would use fireplace matches since they are long enough to reach the pilot light point.
May 27, 2016 | Water Water Heaters
Is there a trick to starting the Pyrox 400? Turned the fan on and press on low then repeatedly press the ignition pilot light, start to smell of gas after a minute. Won't start Help please
Is the ignition sparking? When you press and hold down the buttons, the ignition should be sparking at the centre electrode. At the same time when you hold the buttons down, the gas valve is manually held open to release the gas. The spark is then supposed to ignite the gas. Hold the knobs down for about 3 to 5 seconds after ignition and the gas valve will stay on. If it lights but the flame wont stay on, it could be anything from a partially blocked aeration port to a worn knob. When you push down on the knob, it is supposed to press down on an electromagnetic lock which keeps the gas valve open when the flame is burning. When the knob or shaft isn't pushing down enough, it doesn't keep the gas valve locked and the flame will go out as soon as you let the knob go.
Apr 19, 2015 | Heating & Cooling
Why weber q grill not lighting
Does it have gas? If you take the burner cover off, can you see a spark when you push the igniter button? Is there crud built up around the igniter?
Jul 26, 2014 | Weber Q 320 Propane Grill
Why does the curling iron not stay on and get hot
You have lost a soldered connection on the Circuit Board and it is time to throw it away for your own safety
Jul 17, 2014 | Thermacell Conair Cordless Curls Butane...
Rinnai inbuilt lpg gas fireplace IB35ETR wont ignite. Has good spark but heater does not ignite. LPG is full to large tanks. Other gas appliances are working fine.
Sep 16, 2010 | Heating & Cooling
I have a Progaz heater with a full bottle of gas, the red igintion switch doesnt ignite and/or get the heater going, there is Start then 1, 2 3 on a dial, I have tried it on start and pushing the red...
There could a couple of problems. An easy and inexpensive thing to try is replacing the hose and regulator. If that doesn't help, the pilot jet may be clogged and you have to do some diassembly to get to the pilot jet and clean out the orifice. The last thing is that possibly the igniter is not creating a spark to light the heater.
Jun 26, 2010 | Heating & Cooling
Igniter sparks after several tries but the pilot will not light
no gas is getting to pilot light. if all else fails change thermal coupling, if this is bad no gas will come out.
Nov 05, 2009 | Water Heaters
Wont light
Is there a spark? or do you need a long match? The button usually just opens the pilot so it can be lit. If its not electronic.
Jun 19, 2009 | Pilot Pen Pilot Ignition Gas Water Heater,...
Heating & Cooling Logo
188 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
