Question about Thermwell Prods. Co. SP60 Frost King Water Heater Insulation Jacket
I'm planning to install "green stuff" (synthetic
    Genius:
  • 1,015 Answers
I make no claim on being an expert on this product but from what I have read it will help but I don't believe it will stop it. If you want humidity that low I think the desesrt is your best set.Thank you
Posted on May 28, 2011
  • 2 more comments
  • rissa690 May 29, 2011
    Thanks frodo959. Yeah, I'm inclined to think the same way. What is desesrt? I'm in New Zealand, so I'm not familiar with products available somewhere else.
    Many thanks!!
  • Jack Spooner May 29, 2011
    Well now I feel like the village idiot. Sorry I could not be of more help. Thank you again. Frodo
    Haha!! Sorry! I misread your previous message!! Have a good day!
    may you have a good day and a good year too. Perhaps I can help you with something in the future. Thank you.
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
I HAVE AN ATTWOOD WATER HEATER I LIGHT THE PILOT ON GAS AN PILOT WILL NOT STAY LITE AFTER RELEASING THE BLUE KNOB SO I CHANGE THE HEATING COUPLING AN STILL DOING THE SAME THING
Try spraying some WD-40 in hole where thermocouple attaches to gas valve, then twirl a small piece of steel wool in your fingers and insert it in that same hole and twirl it as you push it in to clean surface where thermocouple makes contact. Then blow out with compressed air if possible and then re-install thermocouple fitting snuggly. If that doesn't do it, you'll have to get a new gas valve/control.
Jul 21, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Have an LP gas water heater with White Rogers control that cycles on and off 3 times before remaining on. Water heater is 5 years old with forced exhaust. Heats water fine once it remains on. Do you...
From what you say, I would CLEAN the thermocoupler with either steel wool or a green scouring pad (dry) and then wipe off the residue with a clean cloth. If you still have trouble then it could be a gas valve that is sticking.
Jul 01, 2011 | White Rodgers Water Heaters
Pilot light stays lit BUT burner will not light
Sounds like gas control needs replacing. Before you do, Shut gas off at valve and your tanks and take a 3/8 or 7/16 wrench and remove the end of the thermocouple that screws in to gas control. Now spray a shot of WD-40in the hole it came out of. Now take a piece of fine steel wool and twirl it in your fingers until it's a few inches long and small enough round to put down in that hole and spin it with your fingers to clean surface where thermocouple seats, well. Use compressed air and blow it out now. Take a little piece of fine steel wool again and rub end of thermocouple that goes in the hole, so it's nice and shiny and clean. Now re-assemble, snug it up and re-try lighting. If pilot stays on, but burner won't light, and your 100% sure water is not already hot, ( check temperature coming out pressure relief valve, carefully) and temperature lever is over to hot setting, then replace gas control. One good indication of a faulty control is if you move the temperature lever all the way over to coldest and back all the way over to hottest and you don't hear it click.
Jun 12, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have model gxrv10ablo1 , and i am unable to install . help me
Well GE manual is certainly careful not to show how to install this thing.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=982440113.PDF
GE parts phone number: 800.626.2002
Blue line connects to bottom of Faucet that comes with unit. I assume the faucet fits in pre-drilled hole in your sink, for example where the spray hose used to connect.
Yellow line connects to top of tank that comes with unit.
Green line connects to cold water line. You might have to make some changes to your cold water shut-off valve to connect green line. If product does not come with a fitting that connects to shut off, then I would probably buy a shut-off that has two connections.
Red line is a mystery. It looks like a discharge line, and the manual is blank on the installation. If the faucet does not have a second fitting, then the red line is probably suppose to rise up to the height of the faucet before dropping down into the drain. This amazingly sanitary plan does not show specifically how to tap onto the drain line, so I suppose you drill a hole and wrap it with some sort of sealant, and then duct tape the red line to side of drain pipe to make sure it doesn't fall out. But I'm not sure what installation method is best for this. It will be a challenge getting your electric drill into the cabinet to drill into chrome tubular drain pipe without bending the tubular wall. Hopefully you have a plastic drain line and perfectly sized drill bit. I can't imagine you're supposed to install a plastic cup under the sink to catch the drain flow.
Manual says you need screwdriver, pliers and a drill. The tool list seems a bit short.
Add a comment here and let others know the details of your installation because you know others have same questions, and they will see this post.
Absolutely feel obligated to upvote the free help.
Or take advantage of fixya paid help.
For a price, expert works with you while you work on smartwater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 04, 2011 | General Electric GE SmartWater Household...
Unit periodically shuts off. LED flashes "13."
it sounds like a dirty flame sencer rub down with emrycloth or fine wool steel if that dosent work need new pilot assembly.
Jan 21, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Sometimes it doesn't light at all other times during use the hot water goes off and the box keeps flashing green as it continues to spark
it sounds like the flame sensor is dirty or faulty. when the pilot lights the flame sensor rod recognises the flame to allow the main gas valve to open and ignite the burners. you can clean the flame sensor with some steel wool or sandcloth
Dec 29, 2010 | Bosch & Tankless LP Hot Water Heater
I want to upgade from my old water tank to a tankless water system. I have underfloor heating and it has 4 zones but i run it as one zone and it is controlled from a therm ostat that controlls a pump.I...
what you have is called a hydronic heating system.
this heating system is completely isolated from your water heater I believe this as most hydronic systems I have installed circulate water through the furnace to heat the house. If this is true you need only to connect your old water heater cold water supply side to the tankless and, old hot water side to the house system: the showers/tubs/sinks etc. in your home.
my appologies if I have missunderstood your inquiry.
Jan 26, 2010 | Rinnai Digital Remote Water Heater Control...
No Instructions - not a water heater
Is it radiant floor heating? I am assuming you're talking about the control unit... Need more information about the type of heater you're using, model, etc. Does it look like this?
http://www.stiebel-eltron-usa.com/radiant.html
If so, it's probably made by their sister company Energy Products.
http://www.energyproducts.biz
You can find the PDF for that heater which includes maintenance, installation, and troubleshooting information for their website.
http://www.energyproducts.biz/PDF/sharkmanual.pdf
Nov 17, 2008 | Water Heaters
Thermwell Prods. Co. SP60 Frost King Water Heater Insulation Jacket Logo
51 people viewed this question
Top Thermwell Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Thermwell Water Heater Expert? Answer questions, earn points and help others
