Question about Abit KV7-V Motherboard
Best video card
Would anyone tell me the best viceo card I need to my Abit KV7--V, also would you tell me, too if I could use a double monitor on this? Thanks!
Yeah, it is but it says that the MOBO does not support 3.3v, and use only 1.5v or 0.8 v, hat does this mean? And also, my other concern, is could this MoBo (Abit KV7-V), support splitting monitor? What I mean is that can I use 2 monitors at the same time , splitting the display?
Thanks for the comment and solution, anyway, I appreciate that.
Posted on Aug 17, 2008
  • 781 Answers
Any video card that is AGP 8X not over and the more ram it has the better 256mb or if you can 512mb
Please post rating
  • David
    David Aug 17, 2008
    Most video card have standard monitor fitting and one for another monitor or TV nowadays
Abit kv7 manual
Try Abit's website.
Get online and got to www.google.com In the google search box type: "Abit Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for manuals throughout the site.
Jun 05, 2012 | Abit : KV7 Socket A KT600 Motherboard
Those not turn on screen or keybord on computer KV7
cek for the cable conector or cek your video adapter ??
Mar 21, 2010 | Abit : KV7 Socket A KT600 Motherboard
I need to replace my Abit KV7-V motherboard what do you recommend?
If your going to replace or upgrade your motherboard, consider this following things:
1. Central Processing Unit(CPU) - Make sure that it can be use to the new motherboard or the motherboard supports your old cpu. If it is an Intel processor, get a motherboard that supports Intel processor or if AMD then get a motherboard that support AMD processors.
2. Memory Card - Make sure that it can also be usable to the new motherboard. If it is DDR then get a motherboard that supports DDR Memory Module or if it is DDR II then get a motheboard that supports it.
3. Video Card(if you have it aside from the onboard video device) - Make sure if you have a AGP Video card or PCI E video card it can be usable to the new motherboard.
Get a new motherboard that support all the stated hardware above.
Hope this could be valuable information for you..:-) Thanks..
Dec 25, 2009 | Abit KV7-V Motherboard
What is the maximum size of hdd to used with abit kv7
Good day sir/maam, yes you can use a 1 TB HDD, get the SATA version depending on the bios but im not sure it be compatible with SATA1 on your motherboard, any new hard disk canor cant be read by any old motherboard, you may have problems with SATA versions, there are 3 versions, but the problem is the response of the hard disk. The rule of thumb, fast motherboards, for large hard disk, because it can access large amount of data very fast usually they are SATA3. So slow motherboards with large hard disk is kinda slow, you be bored. I suggest you stick on the recommended hard disk. If you want extra storage, get 3 hard disk and daisy chained them as master/slave.
Oct 14, 2009 | Abit : KV7 Socket A KT600 Motherboard
Abit kv7 hangs at memory speed
Go into the bios and use the "set bios to default" option
There is another that is used for more speed orientated setting but at this point fo not use it.
Also check the memory settings them selves and set them for auto where possible
If you mean that it hangs when counting the memory then try the ESC key as it is booting to get past the memory check and then use DEL to get into bios
Aug 22, 2009 | Abit KV7-V Motherboard
Intermittent NIC connection
of you have the driver Cd, try reinstalling the driver.
Jan 20, 2009 | Abit : KV7 Socket A KT600 Motherboard
Wiring schematic diagram for abit kv7-v
i have searched the net for a manual for the mobo and nothing comes up not even on abit website,
however wired either way should work as i have many times reset a motherboard by shorting the two pins with a small screwdriver.
hope this helps
Terry
Mar 17, 2008 | Abit KV7-V Motherboard
KV7 upgrade
you might be in luck, the last bios update covers 266 / 333 and 400 fsb cpu's
have a look here
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=2&model=230
Mar 13, 2008 | Abit KV7-V Motherboard
Abit KV7-V Motherboard Logo
89 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
