Question about Microsoft Xbox 360 Console
No HD picture, but standard def is ok
OK so one day I was sitting there playing DMC4 and the picture starts to go green so I restart the system and then no picture... I know this has already been done to death but the only thing is my 360 shows everything fine when in standard def... it's only when you flip the switch on the component cable to HD and switch the wires that the problems start. I have tried different AV cables and different TVs and nothing. Anybody got any ideas? Any help would be MUCH appreciated!
lol microsoft junk should've bought a PS3!
    Filmmaker:
    Uploaded 5 video answers.
  • 97 Answers
That's a weird problem...looks like your scaler chip is failing...not much you can do except try using vga or hdmi converter to see if that would work...good luck
Posted on Aug 17, 2008
SOURCE:
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
Picture problem on Panasonic Plasma tv
Mar 11, 2014 | Audio Players & Recorders
Sony tv picture goes green
HAVE IT REPLACE WITH A NEW ONE
Sep 12, 2012 | Sony Internet TV NSZGT1
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
I can not get my component video to work for my xbox 360 with my with my Toshiba 36A43 Television
Do you get picture at all? What is your resolution setting on the Xbox? That TV is Standard Def. Plus on the plug that goes into the Xbox there is a switch for HD and non. Check and see if its swtiched over to HD. If the Xbox is trying to run in high def on a standard tv you will get no picture. Especially using the the little switch on those component cables. Hope this helps!!
PS...If this does help you please rate my level of help...Have a good day and good luck =)
Apr 23, 2011 | Televison & Video
I turn on my playstation and it works but i got no picture or sound. Recently i took my playstation to a mates place. my tv is standard def. my mates is high def 1080p. when i connected my sony to my mates...
sometimes ps has this problem as i m also havin a ps2 n ps3 n i play them on my standard definition tv ....i also hav to restart again n again till 10 to 12 times then finally it starts this may be a plate problem go show it to ur nearest service center.......hope it works
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
Some games won't run on my PS3 40mb
Hello.
All games should run regardless of the settings. Are they PS3 games or games from the PS1 or PS2? That could also make a huge difference. The 40GB PS3 is not fully backwards compatible. Also, if they are PS3 games, try the reset default video settings. That might even work. Here is how to do that.
Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
I hope this helps. Good luck!!
Jul 24, 2008 | Sony Playstation 3 (PS3) Console
Hi-def dvd
This is not a High Definition DVD player, it does upscale a regular DVD to HD resolution, but that's just an electronic trick.
Also, Toshiba has abandoned the HD-DVD standard (did you find the discs on sale?), you'd need to find a BluRay player (like the Playstation 3) to play high definition DVD's.
Dec 05, 2007 | Samsung HT-Q100 System
Picture problems
The pixelation is probably caused by MPEG2 compression on the DVD and Virgin media video streams, the blur is probably caused becasue you are displaying a standard definition signal on a high definition TV.
However if a high-def source still has these problems then you may have a faulty TV, your best bet is too hook up a high-def source such as a HD/Blu-ray player or PS3/360 games console.
Should a high-def source look ok, then you may have some look changing the display settings on the TV to try and improve picture sharpness and color balance.
Thanks.
Nov 08, 2007 | Televison & Video
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
